Hi guys, so ill try to keep this simple. Purchased an 04 comp g w 84k miles on it in January been lurking on here ever since. So far the car has been a little bit of a handful with some of the "standard GM stuff" leaky sunroof, radio lights burnt out, wheel speed sensors, blower motor relay stuck, (runs constantly have to dc bat atm),valve covers leak, atf leak somewhere(red puddles in snow after long idle) power steering pump noise (fluid full),missing hud/defrost dash panel, rear defrost used to not work but that glass shattered over night last week so its replaced now. This is my second GTP my first having been a 98 with a little over 170k on it and it did not give me nearly the issues this has. I bought this car to be our our main vehicle/my dd, (1st baby on the way and what not) well now that the roads have cleared up more Im noticing sluggish shifts so changed filter/fluid went to new dex maxlife still having slow shifts. Im wondering if the shifts are so slow because its having to relearn shift data everytime i drive the car or if the trans is dying? fluid was dark not burnt, typical "mud" on the magnet few other small shavings/flakes in the pan (more than i have seen in other vehicles in the past by no means a lot). I fear that Im simply feeling overwhelmed with the abundance of stuff on my plate not the car itself and would like a little bit of an outside persepective on it and where to start/what direction to go with it first. Ill make sure I get some photos up for everyone to take a look at. Thanks a bunch for making this sight what it is.
