Thread: 1997 GTP Noob
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: 1997 GTP Noob
    Dec 2012
    Raleigh, North Carolina
    Alright so i will be buffing that out next weekend and attempting to fix the door molding because I'm pretty busy this weekend. For the maintenance, is this the LIM i need? (http://shop.zzperformance.com/store/...ke-Gasket.aspx) and i might as well do the coolant elbows while I'm at it? Maybe shorter dogbones too? Also my car still has Dex Cool, should i keep it or is it really worth switching over to the universal stuff? Thanks for all the help!
  2. #22 Re: 1997 GTP Noob
    those are the lim gaskets, but dont order from zzp. you can find them for 5 bucks less at rockauto. or advance auto.
    you also need a upper plenum gasket, aka sc gasket, its 11 bucks at a local parts store.
    and pick up 3 or 4 feet of vac line and 2 new vac T's cause they always break on you when doing a lim job.
  3. #23 Re: 1997 GTP Noob
    Dec 2012
    ok cool. so i shouldn't worry about switching out the dex cool? And also i forget to mention that my steering wheel controls don't work or light up. (has aftermarket head unit) And i replaced the fuse and they still don't work?
  4. #24 Re: 1997 GTP Noob
    id do a flush of the coolant. what you use it up to you. most of use just switch to green coolant.
    the after market radio is why the radio controls dont work. they do sell a harness to make them work.
    if your airbag light is on that could be why the radio controls dont work too, then you would need a new clock spring in the column.
  5. #25 Re: 1997 GTP Noob
    Dec 2012
    airbag light isn't on. so it looks like i just need a harness although i was thinking about getting a new head unit soon anyways. want it to light up red..
  6. #26 Re: 1997 GTP Noob
    you'll need to search around the site some. but theres how to's for the bulbs to change colors too. but its a lot of small parts and you need to solder the bulbs in. if your up for that go for it.
    they sell the harness at crutchfields. if you look around some here you'll find the right part #. or search crutchfields site.
  7. #27 Re: 1997 GTP Noob
    Dec 2012
    Is this a decent buffer to get? I want to fix the trunk where i debadged and other than that i would just use it for cleaning the GP
    http://www.amazon.com/Peak-PKC0VB-10...orbital+washer
  8. #28 Re: 1997 GTP Noob
    the cheap-o's dont always do such a good job.
    you can get a much better buffer at harbor freight its like 50 on sale this month.
  9. #29 Re: 1997 GTP Noob
    Dec 2012
    So i have been thinking about getting these for my rims.. Will they fit and what diameter? Pictures of them if anyone has bought them would be great too.
    http://www.grafxwerks.com/shop_detai...pid=GPSC1-1043
  10. #30 Re: 1997 GTP Noob
    Dec 2012
    I was hoping to get them for the center caps.. would look a lot better then the abs center caps i have.
  11. #31 Re: 1997 GTP Noob
    Dec 2012
    Anyone?
  12. #32 Re: 1997 GTP Noob
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Measure your center caps see if will work
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  13. #33 Re: 1997 GTP Noob
    Dec 2012
    troll land
    Theyll work
  14. #34 Re: 1997 GTP Noob
    Dec 2012
  1. A nOOb here
    By cich0029 in forum Introductions/Noob Questions
    Last Post: 04-06-2013, 07:43 PM
  2. gtp noob
    By 04gpgtp in forum Introductions/Noob Questions
    Last Post: 03-01-2011, 11:29 PM
  3. Another NOOB
    By frisco49ers in forum Introductions/Noob Questions
    Last Post: 02-10-2010, 01:21 AM
  4. Another noob.....
    By OhsoKleaN in forum Introductions/Noob Questions
    Last Post: 02-08-2010, 12:15 PM
  5. Im the noob
    By 04intimidatorSS in forum Introductions/Noob Questions
    Last Post: 01-14-2010, 03:33 AM
