Thread: I'm at a complete loss..
Results 1 to 19 of 19
  1. #1 I'm at a complete loss..
    Enfield, CT
    I've got a code, P0053 HO2S Heater Resistance Bank 1 Sensor 1, I checked all the wiring and fuses and decided WTH the car has 104k on it I'll just replace the upstream O2 sensor. I did that yesterday and the code came back today. I got this code after I installed my overkill pcm 2 weeks ago. I think it might be the pcm but I found this, http://www.gpona.com/forums/04-08-gr...53-t25763.html.
    The post says:
    This was in the SM (under Document ID 1285788)
    Heated Oxygen Sensor Resistance Learn Reset Notice
    Notice: When replacing the HO2S perform the following:
    • A code clear with a scan tool, regardless of whether or not a DTC is set
    • HO2S heater resistance learn reset with a scan tool, where available
    Perform the above in order to reset the HO2S resistance learned value and avoid possible HO2S failure.
    I do NOT trust going to the dealer to do this because I'm afraid they'll re-flash my overkill pcm with stock tables. Is there anyone who might be willing to help me with this??
  2. #2 Re: I'm at a complete loss..
    do you still have the stock pcm? if so put it back in, see how the o2 react.
  3. #3 Re: I'm at a complete loss..
    Enfield, CT
    thats what I wanna do now. theres a relearn for that tho I think. do you know the relearn procedure? It's an 06 base gp.
  4. #4 Re: I'm at a complete loss..
    if you have the old pcm, aka stock. put it in, it will just work like it used to. same as the new pcm, it will work again when you put it in.
  5. #5 Re: I'm at a complete loss..
    Enfield, CT
    o ok. just throw it in and the car will fire right up?
  6. #6 Re: I'm at a complete loss..
    Antioch, IL
    yup
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: I'm at a complete loss..
    Enfield, CT
    thanks guys. I'll do it 2morrow
  8. #8 Re: I'm at a complete loss..
    Enfield, CT
    I just want to update the status of this situation. I found this TSB on alldata and searched for it online to post it here.
    http://ww2.justanswer.com/uploads/he...0053_P0054.pdf
    I'm gonna do this before I swap the stock pcm back in. I did notice that the first time I got the code was when I remote started the car and that's what this TSB is about
  9. #9 Re: I'm at a complete loss..
    Enfield, CT
    I know it's been awhile but I've been real busy lately. I just put the stock pcm in tonight and drove the car around. Seems ok but I'll have to drive it some more just to make sure the P0053 doesn't come back.
    I lost Cruise Control immediately after I put the Overkill PCM in and now with the stock PCM back in CC still doesn't work! ? Does swapping PCMs have something to do with this?
  10. #10 Re: I'm at a complete loss..
    The BCM won't control anything related to engine codes. (from chat)
    Double check the cruise control fuse and make sure all bulbs work in the 3rd brake light.
  11. #11 Re: I'm at a complete loss..
    Enfield, CT
    Yes Ginseng I did.
  12. #12 Re: I'm at a complete loss..
    Enfield, CT
    I'll double check the CC fuse. All the bulbs in the 3rd brake light? No ****. I'll look into that as well. I've been looking at schematics to see if any wires for the o2 sensor and CC are shared but it doesn't seem to be according to alldata
  13. #13 Re: I'm at a complete loss..
    gardner,mass
    You do unplug you neg battery cable when doing all this right?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  14. #14 Re: I'm at a complete loss..
    Enfield, CT
    All the bulbs work in the 3rd brake light and I triple checked the CC fuse. I put a new 2 amp fuse in anyways but no luck. I'll look at some more schematics and if I don't figure it out, I might just try to contact Billboost and hopefully he can look at it since he's not far from me.
    So far the P0053 code has not come back after 70 miles so I'm sure that codes related to the Overkill I'm sending back later this week
  15. #15 Re: I'm at a complete loss..
    Enfield, CT
    I've got 1 code for the CC after I installed the Overkill PCM. It was P0564 Cruise Control Switch Circuit Malfunction
    but I've never been able to duplicate it.
    This is all I got for schematics. Pretty much useless.
  16. #16 Re: I'm at a complete loss..
    You seem to have a fun problem.
  17. #17 Re: I'm at a complete loss..
    Enfield, CT
    your right I do but it may become your fun problem lol
  18. #18 Re: I'm at a complete loss..
    I sent the pm asking what you were doing Sat.
  19. #19 Re: I'm at a complete loss..
    Enfield, CT
    Problem fixed. Replaced the CC switch and I exchanged the PCM. waiting on the new one.
  1. At a loss here.
    By tmgray01 in forum General Tech Discussion
    Last Post: 08-02-2012, 08:00 PM
  2. One Loss and One Win... so far
    By Kolton Lock in forum Track Sessions and Kills
    Last Post: 03-31-2012, 07:56 PM
  3. Loss of HP
    By black plague815 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2011, 11:38 AM
  4. loss/win
    By WhiteDevil in forum Track Sessions and Kills
    Last Post: 10-14-2009, 11:39 AM
  5. Might get my first loss....
    By Mvfootball1 in forum Track Sessions and Kills
    Last Post: 04-10-2009, 07:44 PM
