Thread: anyone own a 2.4L i think its a 4g60? its in the galant i need help
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    well the title pretty much says it all. I got a few questions. first has anyone ever replaced the head gasket on one? and could you list the steps to do so.
    second which piston is piston one and did you have any problems with timing?
    third question is what headgasket would you recommend.
  2. #2 galant headgasket problems
    Jan 2013
    Tolono IL
    alright so I haven't done a head gasket except on a lawnmower lol but anyway if anyone knows the 2.4 liter engine that they put in these I got some questions
    well first off which piston is number one
    second if anyone has done it do you have the steps to do so?
    and I know this isn't in the right section but im kinda desperate right now
  3. #3 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    I know this is going to sound dumb, but have you tried looking on the galant forums?
  4. #4 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    yeah I did I requested to join like 2 weeks ago and I still cant make a post and I have looked it up several times online and on the forum and couldn't find what I needed.
  5. #5 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Oh. What year Galant? Is it a 92-98 if so its the 4g64.
  6. #6 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    It's a 2000
  7. #7 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Okay its still the 4G64.
  8. #8 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    Ah okay. Yeah like I said never done anything to this engine before so I need help and I don't have money to have it done professionally
  9. #9 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    They also put that engine in the eclipse so try and join one of those forums. I find lots of threads of people swapping out the sohc head for a dohc head with that engine, but haven't really found any how to's.
  10. #10 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    Yeah they put it in the stratus also lol I had one before my gp
  11. #11 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    St. Louis
    This would be a good time to get a Chiltons manual for it. Should list it out step by step. Forums are good to, but I've learned a lot from those over the years. Probably some type of new MLS gasket for it, have the head taken to a machine shop and checked for true, and then new head bolts.
  12. #12 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    how much are those?
  13. #13 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    SWPA
    The hardest thing about doing a head gasket on the 2.0 or 2.4 is setting the damn timing. The tensioner set up is stupid on them. They should have kept a similar tensioner to what was used on the 4g63.
  14. #14 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    the timing is really the thing im worrying about. I built go kart engines and all that so I mean I got some knowledge of a engine. I know car engines are a little different. and whats the easiest way to set a engine at top dead center?
  15. #15 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    SWPA
    When everything is apart you will find the mark on the crank sprocket to get it to TDC.
    We did a 2.4 DOHC swap into my brother's dirt track Neon.
    Thinking about it some more there were two different 2.4's. There was the 420A based 2.4, and the 4g63 based 4g64. As long as they used the 4g63 style timing tensioner you should be okay. I ripped the head off a 4g63T and did a complete headswap and had it running again in 2 hours.
  16. #16 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    alright because someone told me to find piston 1 and put a straw or something long in there and when it stops moving up that's top dead center. is that true?
  17. #17 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    SWPA
    Yeah thats how you can find TDC, but there is a mark on the crank sprocket indicating where TDC is.
  18. #18 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Jan 2013
    Tolono IL
    do you know which one is piston 1? I think its on the far right if your facing the car
  19. #19 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    SWPA
    #1 is furthest from the transmission.
  20. #20 Re: anyone own a 2.4L i think its a 4g60? its in the galant i need help
    Dec 2012
    Where 4T65E's were born
    Chilton says a 2000 Mitsubishi Galant has the 3.0, sohc or dohc. I'd get you the chilton if it listed it right.
    Sold.
  1. 2000 mitsubushi galant over heating
    By lilmidge12 in forum Other Vehicles
    Last Post: 01-29-2014, 05:04 PM
