Well if this snow and cold weather ever let up I will be able to get under the car to check things out for sure.
I may do my wheel bearing that is howling first, then worry about struts and LCA's later.
I don't know. Maybe Dorman doesn't have the proper cross referencing, but every site I put 927100 into says it fits 97-08
I plan on going to the store a little later and will take a peek then. Hopefully township comes through with the plow truck soon. Got another 2-3 inches of snow since they came through this morning.
Putting in my $.2
-Kyb gr2s $200-250
-Monroe strut mounts less then $100
-you can grab some lower mileage stock springs for probably $100 on here.
-reuse strut boots and bump stops unless they need to be replaced.
-97-03 control arms if you feel the need $100
Everything will be even cheaper if you learn to use coupon codes and order online through advice and pick up in store for free!!
Like I said I thought I have read before that 06-08 had the 97-03 style LCA. Now we know.
I just wonder why the 97-03 quick struts don't cross reference.... unless the springs are different. I don't mind a slightly lower ride if I go with the 97-03 quick struts. I just don't want a harsher ride or any negative effects.
alright thanks guys. I'm most likely going to buy new struts and swap the springs etc over and get new mounts. what's the part number for the OES Delco FE3 struts. I'm sure the springs on my car now will work on the FE3s unless the FE3 struts use different springs?
