Thread: XPZ cam + turbo?
Results 1 to 3 of 3
  1. #1 XPZ cam + turbo?
    SE Level Member Dcards's Avatar
    Nov 2013
    United States
    what are your thoughts on a xpz cam in a turbo setup? would it be any better or worse that an st5?
  2. #2 Re: XPZ cam + turbo?
    If you're wanting to swap cams, spec out a custom grind if the ST5 isn't cutting it.
    I'd rather do that than any XPZ-or alike cam on a turbo setup.
    Would it work? Sure. Better? Meh.
  3. #3 Re: XPZ cam + turbo?
    The Boss Iceman6669's Avatar
    Jun 2011
    XPz is a good cam on a turbo.. But ST5 is better.
    2011 F-150 Yote powered
  1. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
