But still...if drivers tire is off ground...and passenger is on ground...the drivers side tire won't spin freely
So all the ones you worked on had 1" chains?
Next ur gonna tell me that if i put a mag steer rack in my non magsteer monte itll b horrible to steer
"But still...if drivers tire is off ground...and passenger is on ground...the drivers side tire won't spin freely"
Correct, because they are linked together by the axle shafts and the differential.
