Thread: 04 GTP newbie with a few questions
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: 04 GTP newbie with a few questions
    SE Level Member GTPNEWBIE's Avatar
    Nov 2013
    Columbia IL
    Quote Originally Posted by 231FUN View Post
    Yup, just dealt with this on the 06 the other day. Bad t-stat stays open and prevents the coolant from getting up to operating temp, usually find this problem when winter hits on a highway drive when car is geting alot of cold air.
    Thats exactly when it came on! i was on the highway going about 65 or so and it was really cold outside
  2. #22 Re: 04 GTP newbie with a few questions
    SE Level Member Zm04gtpcompg's Avatar
    Sep 2013
    Cissna Park, IL
    When the coolant is too low to effectively protect the internal temperature of the engine, the engine coolant temperature (ECT) sensor will provide a false reading to the powertrain control module (PCM). Once the PCM detects the anomaly in the coolant system, the ECT fails to communicate the necessary voltage signal from the PCM, which turns on the "check engine" light.
    If the ECT is bad, you will need to replace it for the check engine light to clear. You can have the code manually cleared, and see if it comes back.
    The thermostat is a very common problem in these cars but as this guy said prolly should make sure it's not low coolant and if so if there's a leak if not it would be wise to change thermostat very easy and flush old coolant out
  1. Newbie questions?
    By chrisSC in forum Southwest
    Last Post: 05-10-2013, 08:57 PM
  2. newbie questions
    By Jackblack99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2012, 02:10 PM
  3. Newbie Questions
    By Widowmaker in forum Introductions/Noob Questions
    Last Post: 11-18-2011, 07:23 PM
  4. Newbie Questions
    By b4rigger in forum General Tech Discussion
    Last Post: 08-16-2009, 04:03 PM
  5. newbie with questions
    By southerndawg09 in forum Introductions/Noob Questions
    Last Post: 08-06-2009, 11:16 AM
