Thread: 04 GTP newbie with a few questions
Results 1 to 20 of 22
  1. #1 04 GTP newbie with a few questions
    SE Level Member GTPNEWBIE's Avatar
    Nov 2013
    Columbia IL
    Hey all, I just got this car and i have a few questions about it.
    1) My HUD doesn't work, like a can hear something mowing up there when i press the arrows but I'm sure what it is that is wrong with it?
    2) Its needing an oil change within the next few weeks or so, so i was wondering what oil to use? it has a sticker that says it used synthetic blend so i didn't know if i should stick with that or go full synthetic like a wanted to?
    3) This really isn't a question but i was wondering if you guys had any suggestions to do to the car (cosmetics wise) for now, then engine wise for later
    http://s1273.photobucket.com/user/Ga...tml?sort=3&o=0
  2. #2 Re: 04 GTP newbie with a few questions
    Search for the thread on the 04+ HUD fix.
    Oil doesnt matter, just run what you want to run.
  3. #3 Re: 04 GTP newbie with a few questions
    Nov 2013
    Columbia IL
    Alright, thanks!
  4. #4 Re: 04 GTP newbie with a few questions
    Your spring needs fixed. Any oil works. I use the cheapest i can with the cheapest filter i can. Tint and lowering will help looks a lot.
  5. #5 Re: 04 GTP newbie with a few questions
    Nov 2013
    Columbia IL
    Is it expensive to fix the spring?? And I'm tinting the windows in a few weeks and lowering in the spring (hopefully)
  6. #6 Re: 04 GTP newbie with a few questions
    do it yourself and it's really cheap. I did mine in about 30 min
  7. #7 Re: 04 GTP newbie with a few questions
    Nov 2013
    Columbia IL
    does it take any parts? or just like put it back together?
  8. #8 Re: 04 GTP newbie with a few questions
    You won't need any parts just a small drill bit to make a new hole for the spring to sit in.
  9. #9 Re: 04 GTP newbie with a few questions
    Nov 2012
    Madison
  10. #10 Re: 04 GTP newbie with a few questions
    SE Level Member CameronMRich's Avatar
    Nov 2013
    St. Joseph MO
    For oil I use Mobile 1 synthetic, with ac Delco filter. Just stay away from Fram as their quality has gone way downhill in the last few years.
    For visual mods checkout PFYC.com. Their is also a SE front lip from GM that is pricey but looks the best IMO. You can swap the GP GXP spoiler for the stock one if you want. Thats all I can think of off the top of my head!
  11. #11 Re: 04 GTP newbie with a few questions
    Quote Originally Posted by CameronMRich View Post
    Why run good oil with a cheap china filter???
    Kinda defeats the purpose.........
  12. #12 Re: 04 GTP newbie with a few questions
    Nov 2013
    St. Joseph MO
    I've always heard AC Delco was alright and that Fram was china made crap??? Maybe I'm mistaken though.
    "If you can't hear the whine then you're behind"
    2004 Comp G - Headers/3" DP/Overkill PCM/3.6 pulley
  13. #13 Re: 04 GTP newbie with a few questions
    Aug 2013
    McDonald PA
    I run nothing but purelator because of their metal internals not cardboard like fram.
  14. #14 Re: 04 GTP newbie with a few questions
    Nov 2013
    Columbia IL
    Quote Originally Posted by Theaceofspades View Post
    The filter I'm guessing you're talking about?
    i also have another question:
    My check engine came on the other day so i went Autozone and they told me my coolant levels were low so i checked and it was low so i put fluid in it. My question is that does the check engine light go off by itself or do i have to clear it??
  15. #15 Re: 04 GTP newbie with a few questions
    You don't get a cel for low coolant. Do you know what the code was?
  16. #16 Re: 04 GTP newbie with a few questions
    Omaha, NE
    When the coolant is too low to effectively protect the internal temperature of the engine, the engine coolant temperature (ECT) sensor will provide a false reading to the powertrain control module (PCM). Once the PCM detects the anomaly in the coolant system, the ECT fails to communicate the necessary voltage signal from the PCM, which turns on the "check engine" light.
    If the ECT is bad, you will need to replace it for the check engine light to clear. You can have the code manually cleared, and see if it comes back.
  17. #17 Re: 04 GTP newbie with a few questions
    Nov 2013
    Columbia IL
    I wanna say something like P128 or something of that nature. I accidentally dropped the paper that said it but it said something like that.
  18. #18 Re: 04 GTP newbie with a few questions
    Nov 2013
    Columbia IL
    Thank you! Im going to have a buddy of mine look at it (he's a chevy mechanic) and have him tell me what i should do about it
  19. #19 Re: 04 GTP newbie with a few questions
    P0128 is usually a bad thermostat
  20. #20 Re: 04 GTP newbie with a few questions
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Yup, just dealt with this on the 06 the other day. Bad t-stat stays open and prevents the coolant from getting up to operating temp, usually find this problem when winter hits on a highway drive when car is geting alot of cold air.
  1. Newbie questions?
    By chrisSC in forum Southwest
    Last Post: 05-10-2013, 08:57 PM
  2. newbie questions
    By Jackblack99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2012, 02:10 PM
  3. Newbie Questions
    By Widowmaker in forum Introductions/Noob Questions
    Last Post: 11-18-2011, 07:23 PM
  4. Newbie Questions
    By b4rigger in forum General Tech Discussion
    Last Post: 08-16-2009, 04:03 PM
  5. newbie with questions
    By southerndawg09 in forum Introductions/Noob Questions
    Last Post: 08-06-2009, 11:16 AM
