Thread: cranks but no start...stumped
Results 1 to 20 of 36
  1. #1 cranks but no start...stumped
    Oct 2013
    fresno
    well I just bought a 97 grand prix gtp, previous owner said it dies randomly, no codes so the process begins. It either wont start at all or starts with the possibility of stalling whenever it feels like it, no stumbling and no loss of power
    I checked for spark none, tested ICM and coil packs ICM was replaced...car started and later died and left me to push it home lol
    Checked fuel pump, hear it prime and also depressed the valve it had fuel.
    Crank position sensor was the next suspect, changed that bad boy out fired right up, did 4 test starts and then test drive. Threw code p0108 Made it threw 5-8 min test drive with no issues. I parked it for a few min came back to start it and nothing. Thats where she sits now, re checked for spark and fuel pressure still had both.
    I read that sometimes the fuel pump resistor can cause this kind of an issue, I have one on order it should be here tomorrow, thats the next test im going to throw at it. Also going to try starter fluid into the T body if it starts then dies I believe that's a bad fuel pump?
    Im really stumped I thought for sure the crank sensor would fix my issue, also it threw a code at me p0108 manifold absolute pressure, would that cause it to crank but not start? I did find a cracked vacuum line and replaced it and it still refused to turn on. It is a gtp supercharged with 166000 on the clock. for the few times it did run nothing struck as being bad, runs and shifts great, loving this car so far just wish it would stay on. Looking forward to what the future holds lol
  2. #2 Re: cranks but no start...stumped
    You can try this and or unplug the maf sensor and then start the car and see if it stays running.
    http://i64.photobucket.com/albums/h1...nmj/relays.jpg
  3. #3 Re: cranks but no start...stumped
    Omaha, NE
    The MAP sensor code makes me think it's an intake gasket leaking.
  4. #4 Re: cranks but no start...stumped
    Oct 2013
    fresno
    lol it happens, and deff will check the hardware store. I love zipties but ill be dammed in Im already zipping a one day old car. As for the code it sounds like you pretty much had it rebuilt? Oh this is going to be fun. Just a thought can I have it smoke tested and hope I get lucky?
  5. #5 Re: cranks but no start...stumped
    Oct 2013
    fresno
    ok, I tried the ideas and neither worked, but i did remember one of the coil pack bolts broke, so i rechecked it and pushed it back down, car fired right up. So I ziptied it down hope that holds. Now onto the code, how would I check the intake gasket for leaks? are there steps up to it or just jump in and start looking? Thanks for your guys help and fast responses
  6. #6 Re: cranks but no start...stumped
    Banned
    Oct 2013
    Moorhead, MN
    I had the map Code when I got mine. Vacuum leak somewhere. I replaced every single gasket.
    The rest sounds like intake, pcv, or battery /grounds.
    Possibly fuel filter.
  7. #7 Re: cranks but no start...stumped
    Banned
    Oct 2013
    Moorhead, MN
    Oh, you got it. Derp. Go to the hardware store.
    The ic bolts are 4.5mm, but 5mm works.
    I replaced all mine.
  8. #8 Re: cranks but no start...stumped
    Oct 2013
    fresno
    I see gm does not list zip ties are a option lol ok well my hopes of having it hot to trot by the weekend is shot, thanks for your help, im going to start with the easy ones and keep digging untill the engine ends up all new, Ill keep you posted
  9. #9 Re: cranks but no start...stumped
    Banned
    Oct 2013
    Moorhead, MN
    Perhaps.
    I rebuilt it.
    I think it was the valve covers or the lim, or both.
  10. #10 Re: cranks but no start...stumped
    Banned
    Oct 2013
    Moorhead, MN
    BOLT,IGN COIL(DELCO-REMY)(HEX WA HD,M4.5X.75X34.5, 28 THD,10.6 OD,GM 6171,GM 1345,TAP)(02.383)(ACDelco #10470758). BOLT-SEAL-STUD, Ignition Coil Mounting. For: H 3.8-1(L67) (1992-1995) (1992 - 1999). Required: 06
  11. #11 Re: cranks but no start...stumped
    Banned
    Oct 2013
    Moorhead, MN
    Check the backside of your UIM. There's a vacuum booster tube back there that can go bad. O-ring. Whatnot.
    Or your pcv valve may just need to be replaced.
    Would a clogged egr set off this code?
    Use maf or electronic cleaner on your maf sensor and air temperature sensor (intake).
  12. #12 Re: cranks but no start...stumped
    Banned
    Oct 2013
    Moorhead, MN
    Tonkinonlineparts.com for diagrams / reference.
  13. #13 Re: cranks but no start...stumped
    Oct 2013
    fresno
    well I looked behind the engine by the fire wall and the fuel vapor purge valve had 2 vacum hoses on the side and theres a nipple on the bottom but no vaccum line. Is there supposed to be one? If so where does it go? The car starts up runs and drives just fine but its dead in the water unless I can fix the dumb code. The purge valve is right next to a delco remy 42871 (I cant find what it is) and it also has an exposed nipple just wondering if they connect?
  14. #14 Re: cranks but no start...stumped
    Oct 2013
    fresno
    thanks thompsju your a stud ill let you know what I find after I check/clean everything
  15. #15 Re: cranks but no start...stumped
    Oct 2013
    fresno
    I have now lol this is more of a project car then I anticipated Ill post back w what I find, thanks for that site
  16. #16 Re: cranks but no start...stumped
    That lower nipple being open to the air is normal. So you have a 97 for sure. lol
    Have you seen this to test?
    http://troubleshootmyvehicle.com/gm/...e-map-sensor-1
  17. #17 Re: cranks but no start...stumped
    Oct 2013
    fresno
    might have it, i pulled off the map sensor and the prongs broke right out, so i deff need to fix the plug, can i just splice a new connector onto the existing wires or is it more complicated than that?
  18. #18 Re: cranks but no start...stumped
    Dec 2012
    Where 4T65E's were born
    Quote Originally Posted by t79z28 View Post
    I don't see why not. You say the terminals in the existing connector snapped off or something?
    Sold.
  19. #19 Re: cranks but no start...stumped
    Oct 2013
    fresno
    ya the prongs stayed on the harness but the plastic part and the rubber gasket came off w the sensor. The prongs are fully exposed, well off for a replacement plug. When I drove it out of the way to get to my other car it acted the same as it has been the whole time so im thinking this is my code
  20. #20 Re: cranks but no start...stumped
    Dec 2012
    Could be, since it says MAP Pressure Circuit High Input, meaning a low vacuum reading(or none)
    Potential causes of a P0108 code:
    Bad MAP sensor
    Leak in vacuum supply line to MAP sensor
    Engine vacuum leak Short on signal wire to PCM
    Short on reference voltage wire from PCM
    Open in ground circuit to MAP
    Worn engine causing low vacuum
    P0108 - MAP Pressure Circuit High Input
    Read more at: http://www.obd-codes.com/p0108
    Copyright © OBD-Codes.com
    Sold.
  1. cranks but wont turn over and im stumped
    By swagcaptain in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-11-2013, 06:47 AM
  2. Engine cranks but won't start
    By PaulGoldstraw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2012, 07:15 PM
  3. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  4. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
