Before i bought this car the power seat worked. As soon as i got in it after buying it, it no longer worked. I figured it was just a fuse but i have changed and tested the fuses. even put a straight wire in the slot for the power seats but to no avail. i went to the junkyard and picked up a new power seat cable(the one that runs under the seat). but in order to get the old one out n put the new one i would find it most easy to just remove the seat and do it since i cant even adjust it higher than where its at. Ive done as much research as i could on removing the seats but almost every site says that the seat must be moved in order to get to the bolts holding it down. So my question is... How can i rig the seat to a battery or something so i can atleast move it to where its comfortable or move it so i can fix it further. any help will help alot.
