Thread: Need assistance, 2 questions
Results 1 to 10 of 10
  1. #1 Need assistance, 2 questions
    SE Level Member whitegt956's Avatar
    Jul 2013
    edinburg,texas
    OK I've had a ongoing problem and as far as I've looked and tried to find answers, I haven't found any....my problem starts when I replaced a CV axle from my 99 gt auto transmission, a noise, OK more of a clack whenever I hit a bump or sometimes when I shift from reverse to drive.....people told me it was CV joints but I had both replaced and only passenger side clacks, any ideas or suggestions are greatly appreciated.
    2.
    Is there some way to do-it-yourself alignment fix at least a better than before fix, I mean I heard you put spacers in old trucks but I don't know if there's a way to fix the alignment on these cars.
    Sent from my Kindle Fire HD 7 using Tapatalk HD
  2. #2 Re: Need assistance, 2 questions
    #1 Check all the hardware you touched on that side to pull/install the axle. Likely you'll find it or your new axle isn't so great.
    #2 Google it up. There's old time ways to measure etc, but none of us will be quite as accurate as the $80 Sears etc computerized laser guided alignment.
  3. #3 Re: Need assistance, 2 questions
    Banned
    Oct 2013
    Moorhead, MN
    #1. Uninstall, Inspect, and reinstall the part. Did you grease the boot? Is it sealed? It could be your hub assembly.
    #2. I'd just bring it in for an alignment.
    But to answer your question, I believe they are called camber kits or something.
  4. #4 Re: Need assistance, 2 questions
    Jul 2013
    edinburg,texas
    OK @BillBoost37 hardware was checked upon installation and professional install...tried googling alignment but random always appears
    @Thompsju if hub assembly is wrong, how can I go about checking that?.....and I finally decided alignment is shop is gonna be final on that
    I looked around and could it also be lower control arm bearing or ball joint?
  5. #5 Re: Need assistance, 2 questions
    Banned
    Oct 2013
    Moorhead, MN
    Check all of your grease boots. If they're torn and/or seeping, that will dry out your bearings and make that awful noise.
    But, eliminate the chance of a faulty install by doing it again. Perhaps find a write-up, have someone inspect the part. (what brand is it?)
  6. #6 Re: Need assistance, 2 questions
    Banned
    Oct 2013
    Moorhead, MN
    I believe the lower control arm boots are ripped on every vehicle in the universe lol.
    Check boots, grease what you can.
  7. #7 Re: Need assistance, 2 questions
    Jul 2013
    edinburg,texas
    Thanks Thompsju I'll do so and see what's up.....
    Sent from my Amazon Kindle Fire HD using Tapatalk HD
  8. #8 Re: Need assistance, 2 questions
    ever change the lower motor mounts? they can make a clanking sound when shifted in and out of gear. pop the hood watch the engine as you shift it fro P to R then to D, if theres a lot of engine movement, the lower mounts are dead.
  9. #9 Re: Need assistance, 2 questions
    Banned
    Oct 2013
    Moorhead, MN
    OE Torque Strut mount bolts may news tightening! Lol
  10. #10 Re: Need assistance, 2 questions
    Professional install doesn't mean the person isn't human. I'd like to think I can install a part as good as a professional etc, maybe better. Yet I'm human and still miss things once in a while.
  1. Need assistance please
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2012, 09:30 AM
  2. Need assistance with Part #'s please
    By gmightymoose in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 09:17 PM
  3. Your Assistance is Needed...Again
    By Remnant King in forum General Tech Discussion
    Last Post: 04-03-2011, 10:30 AM
  4. Bushings Assistance Whereto buy?
    By Mjr Minor in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2008, 04:23 PM
  5. new projectors! need assistance:)
    By blowngt84 in forum General Tech Discussion
    Last Post: 08-28-2008, 08:38 PM
