Thread: 97 ball joint
Results 1 to 9 of 9
  1. #1 97 ball joint
    Aug 2013
    ny
    Hey tryn to do ball joints on a 97. What's the best way to get the top nut off holdin the ball joint. The dam cv joint gets in the way
  2. #2 Re: 97 ball joint
    With this.
  3. #3 Re: 97 ball joint
    once you pop the ball joint free, just buy new lower control arms and install them, new bushings and a new ball joint for about 40 bucks a side cant be beat.
  4. #4 Re: 97 ball joint
    Use a 18mm open end wrench and turn it off as far as you can then pop the ball joint and take it the rest of the way off
  5. #5 Re: 97 ball joint
    Aug 2013
    ny
    K got that. How about putting it back on? Can't get wrench in there. Sorry first time doing any suspension chasis work. Wana make sure it's on there tight
  6. #6 Re: 97 ball joint
    you can get a wrench in there. try turning the wheels one way or the other, it may make the bolt easier to get for you.
  7. #7 Re: 97 ball joint
    Dec 2012
    Where 4T65E's were born
    I fought with mine a little, I just ended up using an open end wrench and penetrating oil to get it off.
    Sold.
  8. #8 Re: 97 ball joint
    Aug 2013
    ny
    Kk Ty. Do I need to put on that rubber boot
  9. #9 Re: 97 ball joint
    Dec 2012
    There should be 1 boot on the ball joint, it needs to stay there.
    Sold.
  1. Ball joint help
    By geetee in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2011, 05:23 PM
  2. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  3. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  4. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
  5. Ball Joint Boot
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2008, 11:17 PM
