Thread: gxp or gtp?
Results 1 to 20 of 28
  1. #1 gxp or gtp?
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    I'm sold my j-body and am shopping for a S/C w-body or maybe a gxp. Figured I'd might as well switch car forums too. W-body will definitely be a step up.
  2. #2 Re: gxp or gtp?
    Dec 2012
    Where 4T65E's were born
    Many will tell you GTP because of how inexpensive it is to mod, and that they can be made as quick as GXP's with some fairly basic mods. Only reason to go to GXP is if you like v8's, and don't like the sound of v6's. You will get the supercharger whine with the GTP though which can be equally as cool.
    They're not too different though. I like the GXP's front bumper better, just going by looks.
    Sold.
  3. #3 Re: gxp or gtp?
    Sep 2013
    Calgary, Alberta
    I've driven both. Been looking at the epa fuel ratings. the v-8 is only 1or 2mpg less than the s/c v6. Is this accurate?
  4. #4 Re: gxp or gtp?
    Dec 2012
    I believe so. It surprises me since it's a v8 but it's tuned down pretty good.
    Sold.
  5. #5 Re: gxp or gtp?
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Yes that's only true if you drive like a granny and you're in DOD/AFM mode alot. I think my car burns a ton of fuel compared to my GTP, and I drove them both the same way. Granted this one is modded now, but stock for stock my GTP got alot better gas mileage... I mean alot! So much so that I've purchased another vehicle for daily driving...
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  6. #6 Re: gxp or gtp?
    I live here. DirtDog's Avatar
    Jun 2012
    My GXP gets pretty decent gas mileage.
  7. #7 Re: gxp or gtp?
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by DirtDog View Post
    what does it work out to be?
    any oil consumption issues from the afm? Reason I ask is the afm trucks are having issues
  8. #8 Re: gxp or gtp?
    Burning oil is so hit and miss.
    My buddy's 2011 silverado burns zero oil and its over 25K miles, then theres this other person we know and his truck burns 1 quart per 3k miles. Which by GM standards is 100% normal. So I wouldnt be turned away by the minor fact that it may burn 1ish quarts per 3,000 miles, figure its only 3-5 bucks worth of oil that you are using for that given time.
  9. #9 Re: gxp or gtp?
    Jul 2010
    Detroit
    I loose about a quart between oil changes in my GXP. Not bad considering my GTP went thru about the same amount with no DOD/AFM
    Ryan
  10. #10 Re: gxp or gtp?
    Sep 2013
    Calgary, Alberta
    the 2011's have a shield over the afm oil pressure relief valve so they won't burn oil. Its the early 2010 and older with afm that are having issues.
    1quart in 3000miles i'm ok with. I just don't want to run out of oil before the oil change is due.
  11. #11 Re: gxp or gtp?
    Sep 2013
    BYRON
    Had both love the gxp better, so smooth such a smooth pull! Never dream a front wheel drive could handle so well!!! Brakes just unreal!!!! And hell the v8 is lighter :-) :-) So cold air, full exhaust and in love!! :-) :-)
  12. #12 Re: gxp or gtp?
    Bunnell, FL
    $1000 headers. For the gxp
    I'm a Sex Offender
  13. #13 Re: gxp or gtp?
    Test drive both and then decide
    04 Comp G.
  14. #14 Re: gxp or gtp?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    when a gen five screams, its just super,
    Pontiac Grand Prix GTP Dyno, Gen V Supercharged - YouTube
    don't know whos car that is, but bolt on a cone filter and your pretty much there.
    (in Edmonton winter I get about mabey 15.5mpgs of pure city. in summer about 18)
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  15. #15 Re: gxp or gtp?
    Sep 2013
    Calgary, Alberta
    [QUOTE
    (in Edmonton winter I get about mabey 15.5mpgs of pure city. in summer about 18)[/QUOTE]
    in the 5.3?
    My 4x4 hemi gets that mpg...for a dd, I gotta have one vehicle that's half decent
  16. #16 Re: gxp or gtp?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Have you considered the 5.3 SS Monte?
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  17. #17 Re: gxp or gtp?
    GTX Level Member blackflag's Avatar
    Virginia
    gtp
  18. #18 Re: gxp or gtp?
    Virginia
    lol i had a j back in 05 before tuning was available. **** platform at that time
  19. #19 Re: gxp or gtp?
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by Seachicken View Post
    That is a fella by the name of Josh who is over on clubgp.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  20. #20 Re: gxp or gtp?
    Jan 2013
    Edmonton, Alberta
    in the 5.3?
    no lol, 07 gt is 3.8sc, i drive like a a$$hole,
    keep in mind im in heavy traffic all day, its a battle just to get home, and in winter i use the factory command start, so it idles for 10-15 mins everytime i go to use it
    depending on what your situation is lots of ppl on here do much better then that with mixed driving
    my car will do just under 28 on long hiway trips
gtp, gxp
