Thread: Heh boost gauge line...
Results 1 to 20 of 22
  1. #1 Heh boost gauge line...
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    How in the world do I get this vac line into the engine compartment. Ive read about a "Go through the drivers side rubber bulkhead boot" Ive got no idea where that is any help would be great im in the middle of hooking up my aeroforce and boost gauge thanks!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Heh boost gauge line...
    Either use the steering shaft boot directly above your feet or run it through the rubber gromment on the passenger side floor under the blower motor area.
    Just poke a small hole in the top of the boot and run the line straight up.
  3. #3 Re: Heh boost gauge line...
    Marysville WA
    Thanks Death Punch! Ill try the steering boot first. I got ten feet of line so I think I should be good.
  4. #4 Re: Heh boost gauge line...
    Marysville WA
    So im gettin the -10 boost reading I read about that same thing with another member what does that mean?
  5. #5 Re: Heh boost gauge line...
    Maybe you didnt tap into the correct spot. The line going to the MAP sensor is where the T should be.
    You'll see -19 to -20 vac.
  6. #6 Re: Heh boost gauge line...
    Marysville WA
    I tapped about four inches from this point, was this not the best place?
    Boost Gauge Install
  7. #7 Re: Heh boost gauge line...
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    How does running the vac line through the boot work? I'm about to go out and fix my lazy vac line job I did.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  8. #8 Re: Heh boost gauge line...
    Quote Originally Posted by ILoveGM View Post
    About time.
    04 Comp G.
  9. #9 Re: Heh boost gauge line...
    Marysville WA
    I actually went through the passenger side opening once I found it it was really easy to pass through but something is wrong cause my gauge is reading in the negative.
    Could there be too much line?
  10. #10 Re: Heh boost gauge line...
    Aug 2012
    Quote Originally Posted by h0wl0ngcanitbe View Post
    I actually went through the passenger side opening once I found it it was really easy to pass through but something is wrong cause my gauge is reading in the negative. Could there be too much line?
    You're never going to see boost. Not unless you're slamming the pedal
  11. #11 Re: Heh boost gauge line...
    The length of the line doesn't matter.
    Make sure you have it tapped to the map and not the Baro sensor.
    04 Comp G.
  12. #12 Re: Heh boost gauge line...
    Marysville WA
    I tapped the line under the snout I hear thats a common place?
  13. #13 Re: Heh boost gauge line...
    Yea that's fine. Are you sure your not getting any vacuum leaks?
    04 Comp G.
  14. #14 Re: Heh boost gauge line...
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    thats the vacuum?
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  15. #15 Re: Heh boost gauge line...
    Marysville WA
    I got some good adapters that couple the stock vac line and go big to the T and they are super snug. Im startin to think its a bad gauge cause its sweeping about 10psi but just in the negative. Its not a big deal it fills the whole in my HUD pod for now and it was a free gauge as part of a package deal
  16. #16 Re: Heh boost gauge line...
    You could always go to advance and buy a cheapo sunpro gauge...try it out and confirm the readings then return it
    04 Comp G.
  17. #17 Re: Heh boost gauge line...
    Marysville WA
    Not a bad idea! It was free to who knows, plus it doesnt match my setup so its not the end of the world if I gotta buy a new one! Do like the HUD pod though it just gives the dash a great look from stock, that coupled with my Humount interior is looking pretty trick!
  18. #18 Re: Heh boost gauge line...
    Dec 2012
    wichita,ks
    When you floor it does it go postive? Just normal driving you won't see boost that's what I can see going on if that's the info I'm getting from this
    It is just a FAMILY CAR
  19. #19 Re: Heh boost gauge line...
    Marysville WA
    No I took her out on the freeway and I hit it pretty hard and it never broke 0 I feel bad I got two threads kinda goin I think this one would be better to continue...
    http://www.grandprixforums.net/boost...ive-82399.html
    Thanks for looking into this, its weird she runs normal but when I floor it at 65 it doesnt pick up and go like it used to the pedal feels hard and not pushy?
  20. #20 Re: Heh boost gauge line...
    Omaha, NE
    Double check the hose and make sure it isn't kinked anywhere.
  1. Boost gauge line location
    By camopaint0707 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2013, 10:23 PM
  2. Whats the best place to run a boost gauge vacum line??
    Last Post: 09-25-2009, 10:16 PM
  3. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 03:18 PM
  4. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:36 PM
  5. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
