Thread: ac/heater not working!
Results 1 to 9 of 9
  1. #1 ac/heater not working!
    Mar 2012
    Hoffman Estates
    got in my 2000 grad prix yesterday and the ac/heater blower does not work on any setting! i tried turning it off switching it to defrost switching it to feet only going from hot to cold nothing! i can hear it changing from different positions but no air flow!
    is this a commom problem on grand prixs ?! if so how do i fix it asap!
  2. #2 Re: ac/heater not working!
    I'm sure with some searching you could have figured this out.
    If no air flow, then the most common thing to come to mind is the blower motor, as that if what makes air move.
    So check the fuse, if thats okay, then likely the blower motor died..
  3. #3 Re: ac/heater not working!
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    yes it is a common issue blower motor might have taken a crap on you
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  4. #4 Re: ac/heater not working!
    Donating Users
    Aug 2013
    Michigan, USA
    On some models resistor also blows. Usually it goes bad because the gasket that keeps the rain water from running off windshield right into air intake fails.
  5. #5 Re: ac/heater not working!
    Mar 2012
    Hoffman Estates
    If I do have a bad gasket ^ is there a right up for that too? I know what your talking about the cowl right above the blower motor?
  6. #6 Re: ac/heater not working!
    Donating Users
    Aug 2013
    Michigan, USA
    This is for 2004 GP but I think it's similar for 2000 as well: Sparky's Answers: 2004 Pontiac Grand Prix, Changing The Cabin Air Filter scroll down to where it mentions water deflector, that's where the common problem exists.
    The gasket itself is fine, they just won't stay where they are supposed to be and when they fall off, it's when water is allowed to pour into the intake and ruin the blower or resistor. Wet passenger side floor also indicates this problem.
  7. #7 Re: ac/heater not working!
    Mar 2012
    Hoffman Estates
    I've had the passenger side floor wet since i bought the car ...
  8. #8 Re: ac/heater not working!
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    In that case, I'd say you need to fix that gasket, and your resistor and blower motor are probably fried. Electrical components don't seem to like being wet for some reason...lol
  9. #9 Re: ac/heater not working!
    Mar 2012
    Hoffman Estates
    Is there a specific write up for the 2000? That deals with a potential fix for this problem?
  1. heater still not working
    By Tyler Sharp in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2012, 07:57 PM
  2. Heater not working
    By JulieC in forum General Tech Discussion
    Last Post: 03-01-2012, 03:05 PM
  3. Heater Not Working
    By teamfbody in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2011, 11:05 PM
  4. Heater stopped working
    By ls1camino in forum General Tech Discussion
    Last Post: 11-08-2011, 02:36 PM
  5. Heater not working properly
    By dms13 in forum General Tech Discussion
    Last Post: 12-13-2010, 07:16 AM
