Thread: 2000 GTP engine knocking. What are engine options?
Results 1 to 5 of 5
  1. #1 2000 GTP engine knocking. What are engine options?
    Jul 2013
    United States
    I know this has probably been answered a hundred times, but I couldn't find a clear answer. The car has the L67 I believe. It has a bottom end knock. What is the difference between the L67 and the n/a version? Is the bottom end the same? Heads? I know from the heads up are different, I'm really just curious about heads down. Any help would be greatly appreciated.
  2. #2 Re: 2000 GTP engine knocking. What are engine options?
    Pennsylvania, USA
    I know the N/A has weaker connecting rods and a higher compression ratio as well.
    In terms of rod strength L32>L67>L36>L26
  3. #3 Re: 2000 GTP engine knocking. What are engine options?
    You can use any 3800 series 2 or 3 bottom end but you'll need the sc heads on up. If you go with a na block it's higher compression so you'll need to keep your KR in check somehow.
  4. #4 Re: 2000 GTP engine knocking. What are engine options?
    Dec 2012
    troll land
    Na doesnt hav weaker rods reseach before posting its
  5. #5 Re: 2000 GTP engine knocking. What are engine options?
    Dec 2012
    troll land
    Series lll na r the ones wit weaker rods hell b using series ll
  1. Engine knocking/odd sound
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 08:12 PM
  2. Engine knocking....help
    By blortz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2010, 06:18 PM
  3. Engine knocking - possibilities
    By GR8racingfool in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2009, 03:15 PM
  4. Engine Rumbling/Knocking, HELP Please :)
    By crusinchub in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2009, 06:46 PM
  5. engine knocking
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 01:50 PM
