Thread: A/C and rear defrost button problem
Results 1 to 2 of 2
  1. #1 A/C and rear defrost button problem
    Indiana
    Figured this would be a rather simple fix so put it in this section...
    2004 Pontiac Grand Prix GT1
    My A/C and rear defrost buttons only occasionally work when I press them. It is almost as if the contact to the switch behind the button is not being made. So I press and press from different angles and eventually it (A/C or rear defrost) will kick on and work just fine. The same when I want to turn the A/C or rear defrost off. The recirculate button works just fine (I assume from little use).
    Any thoughts on how to fix this? Will I need to take the entire panel off? Any idea on a part to replace the buttons and a guide?
    Thank you!
  2. #2 Re: A/C and rear defrost button problem
    Mine works fine. You may need to replace the whole hvac control unit
  1. 3 button DIC to 5 button swap questions
    By pontiacguy86 in forum General Tech Discussion
    Last Post: 10-15-2016, 01:49 PM
  2. issues with rear defrost and blower motor
    By mofford12 in forum General Tech Discussion
    Last Post: 02-04-2013, 11:58 PM
  3. Rear speaker problem
    By Project98GT in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2012, 07:39 PM
  4. Problem with rear brake.
    By WolvesSoulZ in forum Brakes/Suspension/Chassis
    Last Post: 07-15-2012, 12:55 PM
  5. Rear Defrost No Workyyy
    By Curt7 in forum General Tech Discussion
    Last Post: 12-18-2011, 12:40 AM
