Thread: Modifications
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 115
  1. #1 Modifications
    SE Level Member ngj123's Avatar
    Jun 2010
    Michigan
    What are some modifications that I can do to a 98 GTP that are relatively cheap and work? People told me about the chip but I heard that is a waste of money. I already have a ZZP PCM and cold air induction. I have a 3.4 pulley but I am wondering if I should order the whole set or stick with the 3.4 but then a few shops I went to around Taylor, Michigan didn't have any kind of pulley tool so they wanted to charge me $75.00 to do so.
  2. #2 Re: Modifications
    antioch ill
    the chip is just a scam. the pcm and cai wont allow for you to safely drop to a 3.4 get a scanguage first. then get either a plog, downpipe or headers. then you can start to drop pulleys
  3. #3 Re: Modifications
    Banned
    Jan 2013
    Colorado
  4. #4 Re: Modifications
    Jun 2010
    Michigan
    Very helpful, guess I don't have any further questions. Thanks guys
  5. #5 Re: Modifications
    Jun 2010
    Michigan
    Quote Originally Posted by camopaint0707 View Post
  6. #6 Re: Modifications
    Jun 2010
    Michigan
    That is what the guy at ZZP told me first and foremost is to get headers.
  7. #7 Re: Modifications
    I would say get headers or a down pipe before dropping to a 3.4 and first and foremost you need something to scan with. Every car is different what works for one person may not work for the other that's where scanning plays key.
    04 Comp G.
  8. #8 Re: Modifications
    Jun 2010
    Michigan
    Guess I'll be doing some saving. I liked the idea of a $80 pulley versus $1,000 for headers, downpipe with cat, and labor costs. I was going to do that next spring along with the X-P Hot Cam, retainers, and double roller all for about $2,800 at ZZP. Was looking for some quick cheap mods to do right now. I wasted a lot of money this summer by replacing all my gaskets when I should have waited and got everything done together.
  9. #9 Re: Modifications
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    $1000 for headers? More like $300 on ebay
  10. #10 Re: Modifications
    Jun 2010
    Michigan
    I was told to stay away from generic headers sold on ebay, I actually found them for under $250. ZZP gave me this
    In your budget, I would do an XP cam package, PCM, 180 stat, plugs, headers, pulley/belt.
    With labor that will be just short of 3 grand and give you about 270WHP.
    Item
    Qty
    Each
    Price
    Aluminum Coolant Elbows ZZ-ALCE
    Update
    $10.99
    $10.99
    Modular Pulley System ZZ-38MPS-325-BLACK
    Color: Black
    Add On: Add Hub
    Update
    $99.99
    $99.99
    X-P HOT Cam COMP-3312/3314-116+2-XP
    Option 1: Add 140# Springs
    Option 2: Add Modified Retainers
    Option 3: Add Rollmaster Double Roller
    Update
    $664.99
    $664.99
    Autolite Spark Plugs AL-104
    Option 1: 104
    Update
    $11.00
    $11.00
    Alternator Power Cable ZZ-APC-STD21
    Option 1: Standard (2'1")
    Update
    $13.99
    $13.99
    Cam Install Kit ZZ-CAMIP-L67-3
    Option 1: L67
    Option 2: Kit 3
    Option 3:
    Update
    $119.99
    $119.99
    Stainless Headers ZZ-304HDR-38-EGR-MS-C25E
    Option 1: WITH EGR
    Option 2: Mild Steel Downpipe with Cat - 2.5" Exit
    Add On: Add 3 inch gasket
    Add On #2: I am keeping my stock cat
    Update
    $859.99
    $859.99
    Thermostats ZZ-TSTAT-GP180, FP-35666
    Option 1: 180 Degree
    Option 2: Add Thermostat Gasket
    Update
    $12.98
    $12.98
    Serpentine Belts GS-K060653
    Update
    $23.99
    $23.99
    Clear Cart Items
    Save This Cart
    Print Cart
    Subtotal
    $1,817.91
  11. #11 Re: Modifications
    St Thomas Ontario
    if zzp told you that its because they want you to buy their headers lmao, I bought speedy daddy headers off ebay, yes $250 but then shipping taxes etc. their are 100's of people on this site with speed daddy headers. I wouldnt get any other ebay headers though.
    HEADER - STAINLESS STEEL - 97-03 PONTIAC GRAND PRIX 3.8L V6
    only problem I had during install was crossover was a lil off but ill take a slight fitment issue over paying $700 more for the same thing. took maybe a hour then it was on, everything else was great.
    dont get me wrong zzp is great, I got one of their products on my car, but no way woud i pay $1000 for headers when you can get the same thing for $300, they are even people here selling 100% new ones here for cheaper
    heres a link
    http://www.grandprixforums.net/brand-new-sd-headers-sale-80732.html
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  12. #12 Re: Modifications
    Jun 2010
    Michigan
    How much do you think labor is to do headers, if I have an idea I could go to a couple places and through them a number then order off EBAY, but the cam work will be done by ZZP.
    Quote Originally Posted by Grimsin View Post
    heres a link
  13. #13 Re: Modifications
    Lmao ZZP. Hope your smart enough to not believe everything you hear a vendor say. It's about marketing and making money. $3k just for those mods lmao you can get that stuff for much cheaper.
    04 Comp G.
  14. #14 Re: Modifications
    antioch ill
    sd headers ebay 200 shipped. you can get a pulley on here for 30-40 bucks cam maybe 800 all together
  15. #15 Re: Modifications
    St Thomas Ontario
    for 3k you could buy a turbo.
  16. #16 Re: Modifications
    3k you could put a down payment on a faster car.
    Not to mention what your going end up spending to replace that tranny after if grenades so let's see
    04 Comp G.
  17. #17 Re: Modifications
    Jun 2010
    Michigan
    I was trying to go with someone who is trusted and backs up their work. I seen everything on EBAY for much cheaper but I have no shop around me who I trust and who is reasonable. I told ZZP that I had all my gaskets replaced last month and they charged me $500 and he said they would have done it for $350, but they are across state so time and gas was worth the extra $150 for me. Yes I could buy a turbo and within 6 months have to pay $2,000 for a new high output transmission. No thanks just had the trans rebuilt 22,000 miles ago.
  18. #18 Re: Modifications
    Jun 2010
    Michigan
    Ok found these on EBAY Stainless SS Racing Manifold Header Exhaust Grand Prix GTP Regal Impala 3 8L V6 | eBay, what else will I need or are these 100% complete? Also has anyone had any fitment or leaking issues with these?
  19. #19 Re: Modifications
    Those are SDs, some people have issues with the flex section leaking, I've been running mine for almost 2 years with the stock flex. Some people have some issues with them leaking at the slip joints, just use some copper rvt there. Some people have issues with the front 02 hitting the firewall.
  20. #20 Re: Modifications
    Jun 2010
    Michigan
    What about the downpipe, I know SD does not offer this so would I have to use my stock one or order on from ZZP?
    Quote Originally Posted by slick2500 View Post
  1. 04+ appearance modifications
    By Couch in forum 04+ Specifics
    Last Post: 04-11-2013, 04:54 PM
  2. new modifications
    By CountryBoy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2013, 12:55 PM
  3. Modifications
    By Mcbride in forum Introductions/Noob Questions
    Last Post: 08-08-2012, 02:14 PM
  4. Modifications
    By swd2 in forum Introductions/Noob Questions
    Last Post: 05-03-2011, 11:27 AM
  5. Modifications
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 04-25-2009, 08:22 PM
