Thread: need help with where this connector goes
Results 1 to 6 of 6
  1. #1 need help with where this connector goes
    May 2013
    ND
    I was replacing plugs and wires on my 95 GP with the 3100 and for the life of me I disconnected this connector from somewhere and cannot find where to plug it back into. Its been 2 days since I unplugged it and now can't find where to plug it into...lol
    It comes out of the main harness right behind the alternator and this big harness goes into the firewall bottom passenger side. There are a couple of other connectors also, one goes to the alternator and the other goes to the coil packs passenger side.
  2. #2 Re: need help with where this connector goes
    Just a guess here, but from what I normally see the EVAP connector is usually red.
  3. #3 Re: need help with where this connector goes
    Agreed and my first thought, evap is red.
  4. #4 Re: need help with where this connector goes
    May 2013
    ND
    yes the evap connector is red but the evap has the wire connected too it....any other guesses?
  5. #5 Re: need help with where this connector goes
    I could make a bunch of guesses. Reality is.. GM color coded things and that's an evap color.
    Do you have a ps pressure sensor on the bottom of the pump or something like that? Here's how I'd try to find it. Move that wire around in a circle as far as it'll go. Then subtract 2-4 inches of distance because every wire has slack, except your alt connection (it's a 3100 thing). From there.. search for anything that is missing it's connector. Also hook up an OBD reader and see if any codes/sensors aren't reporting or have reported an issue.
  6. #6 Re: need help with where this connector goes
    May 2013
    ND
    still no luck on my end. i looked for 2 hours today with a flashlight and mirror. another problem i have is i
    dont have a obd code reader for a 95 as you know that was an odd year
    ...guess what i was hoping for was someone could go out and look where that one wire goes to from behind the alternator.
  1. Need help connector
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 05:34 PM
  2. right connector?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-03-2010, 10:03 PM
  3. Where does this connector go?
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2008, 09:34 AM
  4. Where does this connector go?
    By alacran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2008, 07:19 PM
