Thread: Shaking while Accelerating??
Results 1 to 20 of 25
  1. #1 Shaking while Accelerating??
    SE Level Member jmdc692's Avatar
    Feb 2013
    Tracy/Sacramento , CA
    I'm rather new to this, but I recently purchased a 2000 Grand Prix GTP and at first on the freeway at about 60+ mph it began shaking but only while accelerating. So I rotated tires and still nothing. After a few days it started shaking even worse and starting to shake at 30+mph. I was wondering if anyone has came across this problem before and or what they did to fix it, any ideas? Thanks.
  2. #2 Re: Shaking while Accelerating??
    CV axle if you ask me.
    Depending on your cars mileage and ability to work on cars, replace both sides.
  3. #3 Re: Shaking while Accelerating??
    Feb 2013
    Its also really bad when im coming off the freeway and I take a right hand turn, it shakes pretty bad. that's what I was thinking though. maybe the axle where it meets the tranny.
  4. #4 Re: Shaking while Accelerating??
    Feb 2013
    maybe cv boots is out of grease?
  5. #5 Re: Shaking while Accelerating??
    You still have to replace the whole axle, if it lost grease or the parts inside failed, putting a new boot with grease on won't fix it.
    I would also double check and make sure your motor mounts and tie rods are in good shape, you don't want any play there.
  6. #6 Re: Shaking while Accelerating??
    GT Level Member JessicaRebel's Avatar
    Jun 2011
    So.Cal: Victorville/Adelanto
    ^^ this. I had the same problem but mine would do it at 30mph+ I had to replace the whole axle and tie rods.
    GPs eat sockets as Cookie Monster eats cookies.
  7. #7 Re: Shaking while Accelerating??
    Feb 2013
    ok ill go ahead and take a look.. thanks
  8. #8 Re: Shaking while Accelerating??
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    mine does this randomly too.. is there a way to tell if the axle is bad if all the boots are connected and sealed?
  9. #9 Re: Shaking while Accelerating??
    Feb 2013
    mines not really randomly more like every single freakin time lol.. I feel like a little kid when ur in a car going on a bumpy road and u hum out loud :P
  10. #10 Re: Shaking while Accelerating??
    Feb 2013
    Illinois
    when you take 90 degree turn slowly (from a stop sign) does it feel like its shaking/catching?
  11. #11 Re: Shaking while Accelerating??
    Feb 2013
    nope. only while coming off an exit and making a long right turn while acceleration. if I let off the gas everythings fine
  12. #12 Re: Shaking while Accelerating??
    Dec 2012
    Hawai'i
    It's your tie rod end. Pretty easy to replace
  13. #13 Re: Shaking while Accelerating??
    Feb 2013
    Illinois
    ya id say its your tie rod ends too...
    i wish that was the case for mine but im not thinkin so
  14. #14 Re: Shaking while Accelerating??
    I still say cv axle, but lets let the OP do some inspecting and see what he comes up with.
  15. #15 Re: Shaking while Accelerating??
    Dec 2012
    Hawai'i
    The way i was told is Jack the car up and on each front wheel put your put your hands at the nine and 3 o'clock positions and try to wiggle it. If it wiggles back and forth that means your tire rod is bad.
  16. #16 Re: Shaking while Accelerating??
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  17. #17 Re: Shaking while Accelerating??
    Feb 2013
    Quote Originally Posted by 1ATony View Post
    Welcome to the site
    Thanks
  18. #18 Re: Shaking while Accelerating??
    Feb 2013
    And I took my car into the transmission shop that i usually go to and the main guy that I really like wasn't there but his mechanics where and they said its my engine mounts. they quoted me $600+ to replace them including the parts. but I passed. I then began to look at them myself and replaced the easiest one which was my the on the driver side. it took away some of the shake but I still strongly believe its the axles. I checked the tie rods and they seem fine. so hopefully this weekend I can change the axles.
  19. #19 Re: Shaking while Accelerating??
    Willoughby, Ohio
    sounds EXACTLY like the symptoms mine had, i replaced both axels and that took care of it. usually the boots rip and after all the grease is scattered throughout your engine bay, the car will shake upon acceleration only
  20. #20 Re: Shaking while Accelerating??
    Feb 2013
    Quote Originally Posted by CTKGP09 View Post
    thanks.. I shall soon find out
  1. Help Shaking when accelerating and makes a squeaking noise.
    By Isidro Luna in forum Brakes/Suspension/Chassis
    Last Post: 07-22-2012, 03:09 AM
  2. shaking at 50-60 mph HELP!!!
    By pink1221 in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2011, 12:36 PM
  3. Shaking....
    By ljmonnin12 in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2011, 11:23 AM
  4. Car is shaking
    By Warlord55 in forum General Tech Discussion
    Last Post: 10-26-2010, 09:28 PM
  5. 02 GTP shaking
    By y2ed in forum General Tech Discussion
    Last Post: 09-27-2010, 03:19 PM
