Thread: Pontiac man from way back.
Results 1 to 8 of 8
  1. #1 Pontiac man from way back.
    Oct 2013
    Ohio
    Hey folks first time here and already need advise. I have a project going pulling the engine from a Grand Prix. I pulled all the bolts out and can't get the engine to separate from the tranny. Need a little help if you please.
  2. #2 Re: Pontiac man from way back.
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    There is 3 areas to check.
    Did you get the "backwards" bolt? The bolt head is on the engine side not the trans side. You can see it looking down the trans from the passenger side wheel well.
    2. Did you take out the torque converter bolt
    3. Did you take off the bracket that goes from the trans to the engine. (by the oil filter)
    97 Bonneville SE Not so much a 97 anymore
  3. #3 Re: Pontiac man from way back.
    Oct 2013
    Ohio
    I did all but the bracket by the oil filter. I thank you Nighthwk12 you have helped a bunch man .Thanks again !!
  4. #4 Re: Pontiac man from way back.
    Nov 2009
    Central Jersey
    It is also way easier to put the reverse bolt back in form the passenger side wheel well. Just need about 3' of extensions. (well worth the investment)
  5. #5 Re: Pontiac man from way back.
    Oct 2013
    Ohio
    Thanks again Nigthwk12 your info is appreciated !!!!
  6. #6 Re: Pontiac man from way back.
    Aug 2011
    'Merica
    Welcome fellow Ohioan. Where you at?
  7. #7 Re: Pontiac man from way back.
    Oct 2013
    Ohio
    I am in a little Village it is call Johnstown, Ohio out by Columbus.
  8. #8 Re: Pontiac man from way back.
    Aug 2011
    'Merica
    Been there....I think
  1. The G8 is coming back! Not as a Pontiac
    By cameron92 in forum Off Topic Discussion
    Last Post: 03-29-2012, 04:26 PM
  2. Could Pontiac come back?
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 06-07-2011, 10:56 PM
  3. pontiac on back bumper
    By pure in forum Visual/Body Modifications
    Last Post: 08-18-2009, 03:03 PM
  4. Back in a Pontiac
    By cmw1876 in forum Off Topic Discussion
    Last Post: 03-14-2009, 04:47 PM
  5. Finally back to Pontiac
    By Big Dave in forum Introductions/Noob Questions
    Last Post: 10-22-2008, 11:22 AM
