Thread: 1995 Grand Prix
Results 1 to 2 of 2
  1. #1 1995 Grand Prix
    Apr 2013
    Elk City, OK
    My car has a problem starting. It will start and cut off, Sometime it will start right up, but after driving for a while, when I turn it off and try to start it, it will start and turn off. If I'm driving under 35, it may turn off. Sometimes at high speeds it becomes jerky. It's getting gas cause I can smell it. Sometimes it will start in neutral with no problem. Has anyone experience this and what is the solution?
  2. #2 Re: 1995 Grand Prix
    Donating Users mystic231's Avatar
    Michigan
    Not real familiar with the '95's (that was during my Ford years) but check the IAC (Idle Air Control Valve) first. It's a small device on the throttle body usually held on with two screws and will have a couple of wires going to it. It opens under low throttle (like idle) to allow air into the engine around the throttle plate which is usually closed. When they get high mileage they usually get sticky with carbon or soot and stick. It's a simple repair and usually under $60.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  1. 1995 Grand Prix GTP
    By Duzaman in forum Introductions/Noob Questions
    Last Post: 08-29-2011, 08:44 PM
  2. 1995 Pontiac Grand Prix v6 help!
    By brokenmercy in forum General Tech Discussion
    Last Post: 06-23-2010, 03:13 PM
  3. Hi all, 1995 Grand Prix a few questions...
    By hitmn4hire in forum Introductions/Noob Questions
    Last Post: 06-11-2010, 07:31 AM
  4. 1995 Grand Prix
    By AML in forum General Tech Discussion
    Last Post: 12-10-2009, 10:06 AM
  5. 1995 Grand Prix SE
    By VGPGT in forum Off Topic Discussion
    Last Post: 04-13-2009, 06:32 PM
