Thread: Alternator to battery bad wire
Results 1 to 10 of 10
  1. #1 Alternator to battery bad wire
    Apr 2013
    MEXICO
    Hi everybody, My first Thread in this forum
    I found there is no continuity between alternator and battery. Suspect of having a bad wire since I place a temporary wire directly from alternator to battery and everything works fine. I do not know where the cable route is, may be a fuse in between or something else. Looking for the schematic to verify wires and fuses. Thanks
  2. #2 Re: Alternator to battery bad wire
    We are going to need to know year and model please.
  3. #3 Re: Alternator to battery bad wire
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    wire goes from the alt to the start has a inline fuse by starter i would just run a new wire to the fuse box to the alt and call it a day
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  4. #4 Re: Alternator to battery bad wire
    Apr 2013
    MEXICO
    Quote Originally Posted by 00grandprixgtp View Post
    Thanks a million, I will check for the fuse, if so difficult to find it, I will replace the wire as your suggestion.
    Best Regards
  5. #5 Re: Alternator to battery bad wire
    Apr 2013
    MEXICO
    Grand Prix 1997, 3.8 L V6 engine, thanks for your answer
  6. #6 Re: Alternator to battery bad wire
    As mentioned, you can run a new wire. I'm not so sure on that fuse though. The wire to the alt is routed in the harness from the top of the radiator onto the engine, the battery cable is routed from the battery down to the subframe and over to the starter.
  7. #7 Re: Alternator to battery bad wire
    Apr 2013
    MEXICO
    Thanks a million Danielle15, I just run a wire directly from the alt to the battery as suggested by 00grandprixgtp and also by yourself. Issue Resolved. BEST REGARDS TO EVEREYBODY IN THE FORUM!!!!
  8. #8 Re: Alternator to battery bad wire
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Quote Originally Posted by javyflores View Post
    Is it a GT?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: Alternator to battery bad wire
    Apr 2013
    MEXICO
    No EJOUIE
  10. #10 Re: Alternator to battery bad wire
    Newnan, GA
    Good. It isn't cursed then.
  1. battery wire
    By Fox in forum Audio, Security & Visual Electronics
    Last Post: 02-20-2013, 02:44 PM
  2. High output alternator vs battery
    By deathjunior in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2011, 11:14 PM
  3. New alternator, new battery, car still dies.
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2010, 12:48 AM
  4. Electrical issues. alternator? battery?
    By Alex W in forum General Tech Discussion
    Last Post: 01-30-2010, 09:18 PM
  5. battery or alternator?
    By noom14921992 in forum General Tech Discussion
    Last Post: 10-01-2009, 08:37 PM
