Ok first things first this is my first post.
I have been looking around for a car to buy and i fell inlove with the GTP.It has power and looks good. Everything i want, so i found one that had a few problems so i got it cheap and now i am working on it. When i first drove it i knew that there was something wrong with my suspension. but i figured hey no biggy. The next day when i had it home i was looking around on it and i lift it in the air the bottom has rust so i sprayed it to try and prevent more. Then when i ripped the driver side tire off i saw that the spring on my strut was trashed (broke a complete circle off it) i knew what was wrong. So i am gonna buy four new ones and put all the way around. Then i changed my oil and back brakes. When i started it after a minute or two it started making a bell ringing noise in the bottom of the motor which it wasnt doing when i checked the car out. It just started after i changed the oil. I put synthedic in it and the right weight. So i took it around the block and it drove fine. Barely lit into it and it laid black for 4ft. So long story short can someone help me figure out what that sound is???
(i bought this car for a project and to mod but did i buy the wrong one?)![]()
