Thread: Needing INFORMATION on 97grand prix 3.8 V6
Results 1 to 4 of 4
  1. #1 Needing INFORMATION on 97grand prix 3.8 V6
    Mar 2013
    Rutherford, TN
    i have 2 fog lights & i have NO clue how to take them out on my car to see if i have one blown or have a short in the wire , can SOMEBODY help me please .. i have looked but idk where at . so please help me out ! Thanks Joanna !
  2. #2 Re: Needing INFORMATION on 97grand prix 3.8 V6
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    First - does your fog lights switch illuminate when you push it?
    Second - check the fuse in the underhood fusebox labeled fog
    If your fuse blows as you as you insert it or when you turn them on you have a bulb that's blown/shorted together or a wire pinched shorted to itself or ground.
    On your 97 if I remember correctly you can go from the bottom or remove the bolts holding the slash guard. It's been so long maybe someone else can chime in.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Needing INFORMATION on 97grand prix 3.8 V6
    Mar 2013
    Rutherford, TN
    its not a fuse so it has to be the light buld itself , im not sure how to take the buld out .
    && i also have a sunroof on my car , yu can hear it move but it wont open ? do yu think its the motor or the fuse on it ? im new to the grand prix .
    my first one . i drove a ford ranger & that was a mistake . I'd really love to know more about them 2 .
    && is it usal for the torce converter to go out on the cars ? ive heard from many pple that they go out alot in the prix .
    ANYBODYS ADVISE WOULD HELP !
  4. #4 Re: Needing INFORMATION on 97grand prix 3.8 V6
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Stick your head under your car where the fogs are. Right behind it you will see the harness. Turn it until its loose. Pull it out. Bam! Ya might even get away with just sticking your hand under there if ya know what to feel for.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  1. Import guy needing help with LIM replacement on an '04 L26 Grand Prix
    By robinsone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2012, 05:55 AM
  2. Pontiac grand prix gt drivers information center dic
    By 99GTP99 in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2010, 04:40 PM
