Thread: Tranny Coolers-
Results 1 to 20 of 22
  1. #1 Tranny Coolers-
    SE Level Member GTByron's Avatar
    Mar 2013
    Florida
    Did some research on tranny coolers and ZZP does not recommend them at all. They quote them rather dangerous than safe. They say that the 4T65e trannys don't have a problem with heat and a lot of people don't realize that. My question is, is it a mod worth the money.? I mean my stupid tranny only slips/shifts hard in the heat so that would make me think that its getting too hot! Has anyone ever installed one? What were the results if so? And why is ZZP saying the 4t65e trannys don't have a heating issue but*people*with this tranny are having the same symptoms in the heat?
  2. #2 Re: Tranny Coolers-
    I live here. DirtDog's Avatar
    Jun 2012
    Usually these transmissions don't get to bad with the 3.8. Its people with the 5.3L that have all the extreme heat problems and have to add a cooler. Do u know what temps your tranny runs at?
  3. #3 Re: Tranny Coolers-
    your tranny is on its way out if it slips when the trans is hot, hotter it gets the thinner the fluid gets. aka clutches are worn out.
    have you done a trans service yet? hows the fluid look? add any lucas to the tranny?
  4. #4 Re: Tranny Coolers-
    How often is what ZZP says right????
    LOL
  5. #5 Re: Tranny Coolers-
    Mar 2013
    Florida
    Quote Originally Posted by marines542 View Post
    I don't know exactly what temp it runs at but its gets hot when I'm sitting in traffic. When I checked the fluid it was dark brown and smelled sour. I changed it 15k miles ago and added 2 bottles of Lucas in between the 15k miles. And it only slips at wot from 2-3.
  6. #6 Re: Tranny Coolers-
    Mar 2013
    Florida
    Fluid is Brown and smells burnt. Will the shift kit help my tranny at all with slippage? Added 2 bottles of Lucas already.
  7. #7 Re: Tranny Coolers-
    Quote Originally Posted by GTByron View Post
    Fluid is Brown and burnt. Will the shift kit help my tranny at all with slippage? Add 2 bottles of Lucas already.
    sounds like its on its last legs. burnt fluid is no good, and after 2 bottles of lucas, and its not helping any more. times up.
    yo could try a pan drop and filter change, and another qt of lucas. but its a crap shoot at best how much longer it will last.
  8. #8 Re: Tranny Coolers-
    Mar 2013
    Florida
    I want to make this tranny last as long as possible. It seem to do fine when driving normal(except when hot outside and it starts shifting hard) so will a fluid/filter change, shift kit, and a tranny cooler extend the life of it?
  9. #9 Re: Tranny Coolers-
    your filter could be clogged up and causing some of this. be warned tho, with bad burnt up fluid and slipping, even a pan drop is a risk if you ask me.
    if you do drop the pan, i'd think you got a 50/50 shot its still working right after the service. it could just no longer work. or it may work just fine. you never know when its in the condition your is in.
  10. #10 Re: Tranny Coolers-
    Arizona
    Yes and no more Lucas just dex6 never flush the trans either
  11. #11 Re: Tranny Coolers-
    dex 6 is thinner,( not what you want now) and we dont know your year car, 6 is for the newer trannys. id stick to dex 3 if your 97-03
    if you dump the pan, id add another quart of lucas as well. with 6 qts of new tranny fluid. should take about 7 qts to refill it in total.
    AND DONT FLUSH IT! that would be a death sentence for sure.
  12. #12 Re: Tranny Coolers-
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Scott can you elaborate on this? When I had my tranny fluid serviced at Jiffy what do you think they did? A flush? Since my fluid change ive had no problems and I was thinking about servicing the tranny again as I am about there again mileage wise.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  13. #13 Re: Tranny Coolers-
    Jan 2013
    Chicago
    Quote Originally Posted by h0wl0ngcanitbe View Post
    I do not have a lot of experience with GP, but im working my way up. I have however been working on diesels and HD CVT transmissions for the last 2 years, and hears my 2 cents:
    The reason not to flush an old tranny is that the material from the clutches has worn off of the clutches and is now in the fluid itself. A pan drop does not replace enough of the "dirty" fluid to kill the transmission after it is in this condition, because the remainder of the fluid still has enough friction material in it to grip and shift. A trans flush will completely remove all of the lost friction material (and probably clogs alot of the ports in the valve body IMO) and your clutches wont grip.
    I have been told by GM for my 4t65 that at 75k the trans should be serviced (pan drop, filter change). after 100k, or "burning" your atf, your pretty much out of luck and you just got to limp it till it dies.
    From experience...I never flushed the trans on my 3.4 impala, and against experienced advice i added lucas stop slip to it around 115k, and broke my imput shaft around 125k. Coincidence probably, but the main point is that it cost me 1800 to fix. Im pretty sure a TE performance tranny will run you about that much no including install.
    My advice before this post turns to a book...dont add any performance parts or shift kits to this tranny, run it till it dies and then buy a new one with a new TC. Or sell the car while its still running and buy another GP in better shape!
    BUILT. Not Bought.
    00 GTP Daytona. 111k and counting
  14. #14 Re: Tranny Coolers-
    how many miles did your trans have when flushed? and had it been serviced before the flush in its life time?
    i used to flush my 97 truck every year, i did put 30,000 hard miles on it a year, and that tranny lasted a long time before it let go. i also owned the truck from new.
    at this point if your fluid is still nice and red looking, service away. cant hurt if its due, like 50,000 miles since the flush. some like to do it every 30,000 miles, 50 the norm tho.
    what happens is the old burnt up dark fluid is full of clutch material, its what is keeping the trans working. if you flush all the old fluid out, and replace it all, the tranny wont work 90% of the time. most jiffy lube places if you have over 70,000 miles and have dark fluid they wont flush it. if you insist they make you sign a waver so you cant sue them if it dont drive out of the shop or fails later on.
    had a friend who was the manager at one of these places. i was hanging out there one day and hes like watch this crap. walk out to a customer comes back with a signed paper, says this car will need a tow truck, the owner wont listen, they did the flush, and then he paid, put the car in gear and nothing. next call was for a tow truck.
  15. #15 Re: Tranny Coolers-
    Mar 2013
    Florida
    Quote Originally Posted by 91parkave View Post
    Dex6? On my dip stick it says use dex3 only. What is dex6?
  16. #16 Re: Tranny Coolers-
    Mar 2013
    Florida
    Oh ok so should I drop pan it or leave it be?
  17. #17 Re: Tranny Coolers-
    Arizona
    Dex 6 is a retro Scotty all dex 3 trans can use it. Did the same in my 97 you can always search as well but hands down dex 6 is a better fluid regardless of fluid condition the same would happen with dex 3 if you put clean fluid in the same could happen. Here's a link BTW. Dexron VI (6)??????
  18. #18 Re: Tranny Coolers-
    from info posted here, its best to keep the dex 3 in a old trans being serviced. dex 6 works, but it is thinner. last thing you want is fluid thats thinner in a old worn out tranny.
    if the older model trans is a fresh rebuild dex 6 is just fine to use.
  19. #19 Re: Tranny Coolers-
    dex 6 is the newest grade of fluid. its for newer cars.
    like i said, its a risk. 50/50 shot. maybe best to milk it along and save up for a jy tranny or used one off craigslist from a part out or something. rebuilds cost a lot. 1500 to 2000 most of the time.
  20. #20 Re: Tranny Coolers-
    Mar 2013
    Florida
    So will the tranny cooler help at all because I'm dropping the pan tomorrow. I will install one if its gonna help with the temperatures.
  1. Police Package 91C Coolers etc
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 01-28-2013, 02:33 AM
  2. Trans coolers
    By BlackGT97 in forum General Tech Discussion
    Last Post: 01-23-2012, 12:41 PM
  3. For those with aftermarket/Aux. trans coolers...
    By Wotgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2011, 03:18 PM
  4. need advice about trans coolers.
    By kirkkarem1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2010, 04:40 PM
  5. Tranny coolers
    By hypnos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 05:50 PM
