Thread: New user saying hello to all and looking for some help
Results 1 to 11 of 11
  1. #1 New user saying hello to all and looking for some help
    Mar 2013
    Durand, MI
    Hello all! First off, I want to say that this forum has been extremely helpful with troubleshooting my girlfriends car.... We are a young couple just getting started in life and I greatly appreciate ALL the great experience and knowledge on this sit. So again thank you!!!!
  2. #2 Re: New user saying hello to all and looking for some help
    Texas
    Welcoeme
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: New user saying hello to all and looking for some help
    Feb 2010
    TN
    Welcome and what can I do for ya?
  4. #4 Re: New user saying hello to all and looking for some help
    Sep 2011
    Copperas Cove, TEXAS
    Welcome to GPF. We help where we can.
  5. #5 Re: New user saying hello to all and looking for some help
    I like to say hi as much as the next guy... but you said you needed. help.
    What's the problem?
  6. #6 Re: New user saying hello to all and looking for some help
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  7. #7 Re: New user saying hello to all and looking for some help
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Welcome!
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  8. #8 Re: New user saying hello to all and looking for some help
    Feb 2010
    TN
    I feel cheated I wanted to help with his problem lol
  9. #9 Re: New user saying hello to all and looking for some help
    Mar 2013
    Durand, MI
    Quote Originally Posted by Logan541 View Post
    okay... 2002 grand prix gt 40th anniversary edition....
    120,800 miles... recently straight piped with u- bend delete and no catalytic converter. installed new 02 sensor. recently did trans pan drop service.... but unfortunately, the quick lube place only used dexron 3 instead of dexron 6....
    The car is throwing MANY codes including p1811... for a while it drove fine, then it started a very mild hard shift.
    hence the reason for the pan drop service ... the car is now doing all sorts of crazy stuff including...
    1. stalling as soon as you put it in park
    2. rpms fluctuate when put in park from 200 rpms to about 1200 rpms.. then stalls.
    3. throwing the p1811 code... and now shifting hard again
    3.5 also throws a code for Throttle Position Sensor....
    4. there was a dreaded moaning noise coming from what sounded like the trans in about second-third gear... while in gear at 40 mph.
    HELP!
  10. #10 Re: New user saying hello to all and looking for some help
    Mar 2013
    Durand, MI
    these are the following things I have done with the car
    1. oil change with new filter and Lucas oil treatment
    2. Transmission pan drop service with new filter, Dex 6 fluid and Lucas Transmission Stabilizer
    3. Cut out clogged Catalytic Converter and put in straight pipe with u-bend delete and new 02 sensor
    4. New Fuel Filter
    5. Listened to gas tank and heard Fuel pump IS coming on, but don't know if it is pumping correct pressure at all times
    6. New Front Right wheel hub bearing assembly/ Wheel Speed Sensor
  11. #11 Re: New user saying hello to all and looking for some help
    Mar 2013
    Durand, MI
    Hello all, I have a 2002 Grand Prix GT 40th anniversary edition non-supercharged... The car has 120,800 miles, is basically stock except for a few small things etc.... I was wondering if anyone could help me with a few questions. I have alot to ask so I guess I will just list the issues.
    1. Car sometimes hard to start since it putters and takes a few seconds to turn over then you have to rev to get going.
    2. More and more frequently, it will drive fine, then once you put it into park, the rpms will start jumping around between 200- 1200 rpms and this is when it usually stalls... only to be started again and be fine.
    3. Car sometimes stalls while driving especially when coming to a stop sign....
    4. Throws code P1811 max adapt long shift and sometimes has slight hard shifts through ALL shifts...
    5. I had the trans fluid and filter changed about 500 miles ago along with Lucas trans treatment.
    6. Because of the stalling, I had the clogged catalytic converter removed and straight piped with a new 02 sensor put in.
    7. Fresh oil change about 500 miles ago and nothing was amiss...
    8 after all this stuff I've done to it, the problems ALL seem to be getting WORSE!
    Now I have read alot on this site about each symptom... with the stalling and fluctuating idle being either bad Throttle Positioning Sensor, Bad Idle Air Control Sensor, Bad Mass Airflow Sensor etc.... The P1811 being Pressure Control Solenoid and Trans-Go Shift Kit to fix etc....
    But I guess my question is this... Could a collection of things going bad be causing my Transmission to act up? Could running without a catalytic converter cause unwanted problems? I am very worried since its my girlfriends second car and we don't have alot of money to just go down the list and replace 2,000 dollars worth of sensors and solenoids only to be too late and be forced to shell out 2000 for a new Transmission.... Any help would be extremely helpful!!!!
  1. Need help new user!!!!!!!
    By lowride150 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 06:45 AM
  2. New User
    By tigercolt87 in forum Introductions/Noob Questions
    Last Post: 05-07-2010, 03:02 PM
  3. Hello, new user
    By chris77 in forum Introductions/Noob Questions
    Last Post: 03-22-2010, 08:43 PM
  4. new user
    By bross in forum Introductions/Noob Questions
    Last Post: 12-17-2009, 12:47 AM
  5. hello new user
    By clarkracin337 in forum Introductions/Noob Questions
    Last Post: 12-15-2008, 06:18 PM
