Thread: Newb with odd question...
Results 1 to 16 of 16
  1. #1 Newb with odd question...
    SE Level Member Razer440's Avatar
    Mar 2013
    Michigan
    I just got a 2002 GP GT w/103k and it has some, shall we say a few minor quirks. I don't wanna make more power or do any major mods just wanna know one thing, Why the hell won't my washer fluid spray???? I tried several times and nothing. I looked to see if a hose was disconnected, nope no puddles on the ground indicating a washer hose wasn't connected. Yes the washer tank was full of fluid. What is the problem? Is it an easy fix? How expensive is it going to be to fix? Also when I go over some bumps the trunk light on the dash flickers or blinks which I would think is a minor electrical issue. A short or bad connection maybe? Any help would be much appreciated.
    Thanks
  2. #2 Re: Newb with odd question...
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    check out this thread. He had the same problem as you
    http://www.grandprixforums.net/washe...ing-56762.html
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: Newb with odd question...
    Mar 2013
    Michigan
    Thanks man. I appreciate it.
  4. #4 Re: Newb with odd question...
    I'm assuming you aren't trying to wash the window by hitting the "mist" button? I've seen it.. Just asking.
  5. #5 Re: Newb with odd question...
    Mar 2013
    Michigan
    Yeah I am, it won't spray washer fluid and the tank is full.
  6. #6 Re: Newb with odd question...
    Sep 2011
    Copperas Cove, TEXAS
    Have you pulled the inner fender well on the right side and listened to see if the washer pump is working, checked all your fuses?
  7. #7 Re: Newb with odd question...
    Mar 2013
    Michigan
    No I didnt, I just bought a new washer pump. It was only $16, so not going to break the bank. Where is the fuse panel located? I looked in the under the dash on both drivers side and passenger side. I'm new to GM cars so don't laugh at me too much. lol
  8. #8 Re: Newb with odd question...
    Uh..if you are pressing the mist button, that's not going to work the pump. You need to press the wash button. On the 97-03's it's closer to the wheel on the same stalk as the mist button.
  9. #9 Re: Newb with odd question...
    Mar 2013
    Michigan
    I tried both nothing worked. The pump was shot. It was burned out so I bought a new one.I also wanna know if there is a way to turn off the daytime running lights? I tried to pull the fuse in the glove box but when I turned my car on, the lights flasshed rapidly and I heard a ticking noise from under the dash on the drivers side of the dash board. Any Ideas of what that was about?
  10. #10 Re: Newb with odd question...
    SWPA
    Another Stealth owner comes to GPF.
  11. #11 Re: Newb with odd question...
    Mar 2013
    Michigan
    Another Stealth guy? Who's the other Stealth owner?
  12. #12 Re: Newb with odd question...
    SWPA
    Quote Originally Posted by Razer440 View Post
    I bet you would reckognize my sig pic from 3sgto and (formerly) 3si if I posted it.
  13. #13 Re: Newb with odd question...
    Mar 2013
    Michigan
    Holy Crap!! I think I already do know who ya are. LOL I'm surprised I didnt catch that! Wow man small world. lol
    Hey I need some input here. I need to replace my head light lenses on the GP due to the bad hazing thats starting. I have tried the head light restore stuff and its not working, They need to be replaced. Anyway I'm thinking about getting some Black Euro Crystal Headlights like these. http://www.carpart4u.com/images/prod...ghts_Black.jpg
    Was wondering if anyone has these and how much light they cast. Does the Black bottom absorb any light? Or should I just get the OE replacement lights? Oh I found Black Euro Crystal Headlights online for a few buck less then the OE replacements.
  14. #14 Re: Newb with odd question...
    Jul 2012
    Chicago
    Look above ya. ;D
    -Carl
  15. #15 Re: Newb with odd question...
    SWPA
    I've seen a few cars on here with those lights and they look good. If I had a 97-03 those would be the ones I would go with.
  16. #16 Re: Newb with odd question...
    Mar 2013
    Michigan
    Thanks. I ordered the OE headlights instead. That way there's more money for the stealth TT LOL 400 HP TT here I come. lol
  1. Tire question from a newb
    By Yost24 in forum Tires & Wheels
    Last Post: 07-13-2012, 06:47 PM
  2. i feel like a newb pulley size question...
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2011, 08:13 AM
  3. Newb Question about 4th gear upshift
    By mtcimpala in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2009, 07:38 PM
  4. I guess a newb question about trans fluid
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2008, 02:00 AM
  5. Grand Prix newb with a start off question
    By PontiacBoy13 in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:16 PM
