Thread: 1998 silvermist gtp here
Results 1 to 6 of 6
  1. #1 1998 silvermist gtp here
    Mar 2013
    new port ricehy florida
    I figured i'd post a few words here. I have a silver mist 98 gtp coupe and i had a friendly race with a local who's on here his screenname is quicksilver something i don't remeber the rest... well here's the mods i have done stock puley ported blower with the silencer ports welded shut drilled 160 stat open cone intake bbv bypass weight reduction hpt tune cat u bend res delete al 104 plugs... i know i'm forgetting something i know it.. well i look forward to posting here..
    Benjamin
  2. #2 Re: 1998 silvermist gtp here
    Canton, Ohio
    Welcome to the forum!
  3. #3 Re: 1998 silvermist gtp here
    Hi.
    160 thermo is doing more harm than good right now, and 104's are far too cold, just sayin.
  4. #4 Re: 1998 silvermist gtp here
    Mar 2013
    i live in florida so the 160's gonna help with the heat when it gets hot here and the 104's are gonna fight kr also when it gets hot i ran a 14.2 on this setup with a halfass tune
  5. #5 Re: 1998 silvermist gtp here
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    104's are still to cold.
    Since you're on the stock pulley I recommend AL606 coppers or AL605's at the most.
    160* tstat is also to cold. Whether you live in Florida or not. Get a 180* then.
    Boost Bypass - Bypass mod is not a "mod" and should not be done. It is there for a reason, don't bypass it.
  6. #6 Re: 1998 silvermist gtp here
    < Florida resident
    You don't need the 160 its doing you more harm them good right now. Throw the stock back in get a tune then go with a 180 if anything.
    Plugs are to cold switch to some 606s.
    04 Comp G.
  1. New GPOs on a Silvermist.
    By Moydynasty3 in forum Visual/Body Modifications
    Last Post: 10-02-2009, 12:00 PM
