Thread: Screeching sound, but not from belt
Results 1 to 7 of 7
  1. #1 Screeching sound, but not from belt
    Feb 2013
    Santa Cruz
    2002 Pontiac Grand Prix 3100 SFI
    Engine makes a high pitched screeching sound when engine is revved.
    The sound is coming from the left side (front) of the motor, where the belt runs.
    When driving, the screeching occurs when accelerating to highway speeds, or when climbing slight grades, there also seems to be a loss of power.
    Backing off the throttle will stop screeching, and you'll be driving like granny.
    I thought it was the belt, or a belt driven accessory like tensioner or water pump etc.
    With the hood open I removed the belt and did a quick test. When I revved up the motor it still screeched... NOT GOOD!!!
    It runs smooth and quiet until I accelerate hard or try climbing a moderate grade. If I drive like granny there's no problem!
    What internal parts could be causing this?
    Has anyone else had a similar problem?
  2. #2 Re: Screeching sound, but not from belt
    Internal, you don't want to go there.
    Might be a bad balancer, typically not a screech, but can be. Since you pulled the belt, that gets many other things out of the way. Might be a PCV malfuntioning.
  3. #3 Re: Screeching sound, but not from belt
    Feb 2013
    Santa Cruz
    I pulled and inspected the PCV... it's clean and working fine. There is no excessive internal vacuum or back pressure.
    If I punch the throttle I can get a quick screech (just like a belt would make).
    If I slowly increase throttle, it will run smooth until about 3500-4000rpm before it starts to sound off... and all this happens with the belt off???
  4. #4 Re: Screeching sound, but not from belt
    LaBarge Supercharged sseilmnop's Avatar
    Mercer, Pa
    Try running with the oil filler cap off. You may be getting to much vacuum built up in the motor and removing the cap will stop it.
    Adapters, Phenolic Intercoolers, Supercharger Parts & TVS2300
    http://stores.ebay.com/QualitySuperchargers
  5. #5 Re: Screeching sound, but not from belt
    Feb 2013
    Santa Cruz
    I forgot to mention, I tried that too!
    I'm thinking bearing, pushrod, or even a valve guide that's generating the noise ?
    Whatever it is, it's not going to be fun!
  6. #6 Re: Screeching sound, but not from belt
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by LeoD View Post
    video plz
    pushrods/ valve guides cant "screech" unless you press em against a chalkboard
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  7. #7 Re: Screeching sound, but not from belt
    Mercer, Pa
    Okay. On 3800 if your PCV vent line gets plugged it builds vacuum and the front seal squeals just like you describe.
  1. Brakes screeching
    By Steven Monteith in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2012, 12:56 AM
  2. Loud screeching from drivers axle
    By Elite6 in forum Brakes/Suspension/Chassis
    Last Post: 09-13-2012, 01:25 PM
  3. Loud Screeching Sound
    By Btownmills in forum General Tech Discussion
    Last Post: 05-20-2012, 07:42 PM
  4. Whining sound from Belt area
    By jonnyo81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 09:57 PM
  5. New CV axle, Now loud screeching...
    By Greinerts in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2009, 12:58 AM
