Thread: lowering springs
Results 1 to 9 of 9
lilmidge12 lowering springs 02-19-2013, 09:37 AM
REDCRAPGP Re: lowering springs 02-19-2013, 09:38 AM
lilmidge12 Re: lowering springs 02-19-2013, 09:41 AM
Aaronfrom Re: lowering springs 02-20-2013, 12:04 AM
REDCRAPGP Re: lowering springs 02-20-2013, 04:08 AM
coolone Re: lowering springs 02-20-2013, 06:28 AM
lilmidge12 Re: lowering springs 02-20-2013, 09:29 AM
REDCRAPGP Re: lowering springs 02-20-2013, 09:48 AM
lilmidge12 Re: lowering springs 02-20-2013, 01:27 PM
  1. #1 lowering springs
    Jan 2013
    Tolono IL
    i been reading a lot on here about springs and one of the springs i want says only for the GTP and i have a GT...will it still fit? i feel like it would and would wheel spacers make a difference in a good way?
  2. #2 Re: lowering springs
    There's nothing different about the suspension setup up from a GT or a GTP.
    So yes they will fit
    04 Comp G.
  3. #3 Re: lowering springs
    Jan 2013
    Tolono IL
    thats what i thought..do u know anything about wheel spacers?
  4. #4 Re: lowering springs
    Feb 2013
    Saskatchewan
    trust me, you dont want wheel spacers unless your running thinner tires, which would be crazy to do. spacers in my opinion are a waste of money if youre not drive a big lifted truck. and also, look into "coil overs", my buddy has them on his BMW 330ci and they look deadly! much better than lowering springs. and if youre going to do lowering springs or coil overs, you might as well replace the control arms with adjustable ones. if pure ever feeling dope you can give your car a little camber
  5. #5 Re: lowering springs
    ^ em you realize springs are around $200 or less and coilovers are $1300ish. Not budget friendly for a lot of guys and he may not be wanting to go that low and adj control arms are another $500 or so. It's a Grand Prix it won't handle like a Subaru.
    Spacers..depends on what your attempting to achieve. I have no problem with a minor spacer to give your wheels a bit more poke but only recommend it if your lowering it. Are you wanting to do it on stock wheels? How much of a spacer are you thinking?
    There's a great thread on spacers in the suspension section.
    04 Comp G.
  6. #6 Re: lowering springs
    Nov 2011
    NY
    Bewildering how these sections are continually missed for some inexplicable reason!
    lolz...
  7. #7 Re: lowering springs
    Jan 2013
    Tolono IL
    my friend found lowering springs for 250 that will give me a 2in drop...im going with those but is there anything else i should buy that way some parts dont go out as fast?
  8. #8 Re: lowering springs
    Quote Originally Posted by lilmidge12 View Post
    Check the suspension section there is a sticky with the information you need. Not trying to be that guy but the information is out there and guys have taken the time to put it there to avoid this common questions.
    04 Comp G.
  9. #9 Re: lowering springs
    Jan 2013
    Tolono IL
    alright i will look thanks!
  1. Looking for Lowering Springs
    By 505pike in forum Wanted To Buy - Parts
    Last Post: 02-26-2013, 05:34 PM
  2. Zzp lowering springs
    By rperry435 in forum Brakes/Suspension/Chassis
    Last Post: 11-26-2012, 12:55 PM
  3. Lowering Springs
    By caseycour in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2009, 09:21 PM
