I have a very very small coolant leak, it takes weeks for any to leak out. The radiator sealant I got say to run an high idle after pouring the radiator sealant into radiator until the leak is sealed. How do I know when a leak that small is sealed?
you fudged up never use additives in the coolant get rwady to replace the radiator and heater core
good dont is it thr rad for sure that is leaking
Yeah don't use any additives unless ur selling or just don't care about it. It'll gum up and plug coolant passages.. Heater core would be a big one.
I'd just put a new radiator in they arent that expensive
Sent using my Galaxy SIII on Tapatalk 2
ok I wont use it. It was free anyways, I got it a year ago for my last car, but never end up using it. I'll just add the 50/50 coolant I bought, to replace the water I added that has leaked out/evaporated. I just been adding water since I bought the car few months ago. I got the real deal now.Thanks guys!
my car also has a leak some where but i cant find it i just add a quart every month or so
have you repaced lim gaskets?
a person with basic knowledge can do it. the kit is like 90 bucks at advance but i comes with everything you need except the supercharger gasket
there is a video on how to do it first go out to your car and look in between the head and lim if you see black plastic gaskets replace them if theres metal its been done before
If your lim gasket is black plastic it needs changed. Look at the lim and head where they meet
are you gt or gtp
wish i had a picture to show you
