Thread: 3.4 setup questions
Results 1 to 8 of 8
drewhanover 3.4 setup questions 01-29-2013, 01:56 PM
Fivefingerdeathpunch Re: 3.4 setup questions 01-29-2013, 01:59 PM
JDrach Re: 3.4 setup questions 01-29-2013, 02:01 PM
dsmuts Re: 3.4 setup questions 01-29-2013, 07:13 PM
drewhanover Re: 3.4 setup questions 01-30-2013, 11:13 AM
TLSheff Re: 3.4 setup questions 01-30-2013, 11:41 AM
REDCRAPGP Don't believe what ZZP... 01-30-2013, 11:31 AM
drewhanover Re: 3.4 setup questions 01-30-2013, 12:01 PM
  1. #1 3.4 setup questions
    Nov 2012
    Bay City, MI
    So i'm wondering how much it will cost to go to a 3.4 setup.
    Figuring parts needed will be headers, downpipe, 3.4 pulley, HAI, some type of scanner and a tune.
    What kind of horsepower gains will i see from this? Where can i get a tune from? How much is a tune?
    Note that this is my DD.
  2. #2 Re: 3.4 setup questions
    Read the modding thread chief.
    Do some research.
  3. #3 Re: 3.4 setup questions
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    http://www.grandprixforums.net/safel...0-a-67580.html
    i'd say roughly 600$ or so. Depends on what you get exactly as far as brands for certain parts go.
  4. #4 Re: 3.4 setup questions
    I have about $200 in my 3.4 setup.
  5. #5 Re: 3.4 setup questions
    Nov 2012
    Bay City, MI
    i guess following zzp's recommendations you only need u-bend delete, intake, colder plugs, colder therm, and 3.4 pulley. how many people are going to tell me otherwise?
  6. #6 Re: 3.4 setup questions
    I live here. TLSheff's Avatar
    Quote Originally Posted by drewhanover View Post
    U-bend delete will allow more flow but not enough considering you will end up with about 4-5 more pounds of boost. This is why we say headers, bigger primaries, bigger piping, better flow for the added air into your motor. Lean causes pistons to chip and a blown motor, you don't want this. Get headers.
    Colder plugs on a 3.4 setup is not ideal. You want the spark to be as hot as possible without causing KR, once you get into a cam, intercooler, meth setup, or something bigger than a basic 3.4 setup you DON'T need to drop to a colder plug, not this early. Factory iridiums are best. Platinums get eaten by boost in these motors, go with iridiums.
    Colder thermo stat depending on your area. Some prefer a 180* thermo, like myself (Bear in mind is currently 50* in Oklahoma and this is cold). Considering you are in Michigan where winters are cold, with a 180* thermo it will take a while to get to operating temps and that could be harsh on your motor. During summer weather you could do it ok, but during colder months you want the factory 195* thermo. 160* is insane, do NOT even consider it.
    Tune is everything, Need to have it checked while driving with a 3.4 after a tune to make sure you motor is ok with that pulley. Some motors love a 3.4, some still show KR, every motor is different. Thinking your ok because someone on the internet had these parts and they had no problems doesn't mean you won't blow your motor. Safe is the key, unless you like blowing motors, in which case GO FOR IT!!!
    ^ Referenced for a reason. If you don't want the flaming, listen and learn.
    Don't believe what ZZP recommends they are a business and want you to continue to purchase. Every far is different what works on one may not on the other.
    Headers,intake,plugs,tune and first and form most something to scan should allow you to run a 3.4.
    Read the moddin thread again.
    04 Comp G.
  8. #8 Re: 3.4 setup questions
    Nov 2012
    Bay City, MI
    ^This is what i was looking for. the safely modding thread only tells me what to do, not why and when. Thanks for the productive response.
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. Light Setup Questions
    By cowgirldani in forum Visual/Body Modifications
    Last Post: 04-14-2010, 08:07 AM
  3. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  4. 3.4 setup questions.
    By Perry125 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 04:01 PM
  5. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
