Thread: Should I put in a shift kit and change all 5 solenoids?
Results 1 to 6 of 6
  1. #1 Should I put in a shift kit and change all 5 solenoids?
    Jan 2013
    Wausau, wi
    I'm in the middle of changing the solenoids too fix the p1811 code. Just woundering if i should put in a shift kit to?
  2. #2 Re: Should I put in a shift kit and change all 5 solenoids?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    YES.....if you're going through all that trouble why half ass it. Drop the $50 and at least get the TransGo shift kit. Very simple and helps firm up the shifts a bit. It's not the most aggressive on the market but is well worth it.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: Should I put in a shift kit and change all 5 solenoids?
    Jan 2013
    Wausau, wi
    Thank for replying. Is there different levels or spring in the kit?
  4. #4 Re: Should I put in a shift kit and change all 5 solenoids?
    Apr 2011
    Columbus, OH
    There are no levels in this kit per say but there is a combination of using old and new springs that will help firm up the shifts a little more over the standard TransGo kit. I'd have to go hunting for the directions but what I've done in both of my GTP's is make the 1-2 and 2-3 solenoids look the same. Use spacers as directed and then use the same combination of springs for both. Then for the 4th accumulator I use the 2 springs in the kit along with the stock spring make a total of 3 springs in the 4th housing.
  5. #5 Re: Should I put in a shift kit and change all 5 solenoids?
    Apr 2011
    Columbus, OH
    Here are the instructions for a little bit more of a visual.
    Here is where you can see that I use the spacers as directed but use Plain, White, Red for both accumulators. This helps firm up the 1-2 shift just a little. You can also order the 2-3 spring that goes above the piston and use that for the 1-2. GM part number 24203977 is for the spring and will also help firm up the 1-2 shift.
    Since I used the Red spring in the 1-2 accumulator what I do is leave the 2 yellow springs that come stock in the 4th accumulator and then add the last remaining yellow springs that comes with the kit. There will end up being 3 yellow springs all said and done.
    Here is another good resource if you wanted to go the DIY way.
    http://www.w-body.com/showthread.php...-Install-Guide
  6. #6 Re: Should I put in a shift kit and change all 5 solenoids?
    Jan 2013
    Wausau, wi
    Great, Thank for the pics. that helps me know what I'm get in too.
    Thank for the advice
  1. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  2. how to change shift indicator light?
    By nwulf1 in forum General Tech Discussion
    Last Post: 02-17-2011, 03:04 AM
  3. Shift Solenoids
    By txturbo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:55 AM
  4. Transmission Solenoids
    By japslpr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 04:13 PM
  5. Does the trans need to be dropped to swap out shift solenoids?
    By bminior in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-08-2008, 08:59 AM
