Thread: 01 grand prix gt
Results 1 to 3 of 3
  1. #1 01 grand prix gt
    Jan 2013
    wisconsin
    My key was stuck in the ignition. I removed the solenoid as seen in another forum. It appears where the top of the solenoid went into the lock mechanism there is a pin in there that is sliding around and occasionally still causing the key to not return to the lock position. if I jiggle the key or take the pin from the old solenoid and push it into the hole I can then get the key out. How do I get the pin out of the housing? Thanks Dave
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    That solenoid most likely isn't working due to the signal from the shift lockout in the shifter I would look there that's usually the cause in the shifter
  3. #3 Re: 01 grand prix gt
    Donating Users mystic231's Avatar
    Michigan
    Ditto that. My 1998 had a broken wire in the shifter harness inside the console. As a result the key wouldn't release without pulling the plug out of the bottom of the column and manually releasing it. I fixed the wire and problem solved.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  2. Replies: 23
    Last Post: 06-21-2013, 12:52 PM
  3. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  4. 1991 grand prix 3.1 swap into 1996 grand prix 3.1
  5. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
