Thread: how do you remove the throttle body mesh?
Results 1 to 20 of 20
  1. #1 how do you remove the throttle body mesh?
    Jan 2013
    Sioux Falls, SD
    I tried searching but got nothing. I tried removing it with a bent needle but all i did was bend the mesh a bit. Any tips?
    Thanks!
  2. #2 Re: how do you remove the throttle body mesh?
    theres a ring clip around the screen, use 2 nails or picks to squeeze the ends together to remove it.
  3. #3 Re: how do you remove the throttle body mesh?
    Jan 2013
    Sioux Falls, SD
    After that it just falls out?
  4. #4 Re: how do you remove the throttle body mesh?
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    whyw would you remove, that serves as a air flow straightner for more accurate reading for the MAF..?
    2009 mazdaspeed3-self tuned Cobb AP,Custom water to air IC,3" intake, 3" DP' 3" exhaust, Forge Wg actuator, Ricer mods, Cobb suspension
    2004 mazda 3-custom big turbo kit, blew up 4x went back stock (Details/pics ask)
    1997 GTP S/C 3.4 pulley, intake, all i know so far.
  5. #5 Re: how do you remove the throttle body mesh?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    nope it is stuck in their good lols
    i took 2 big paper clips then bent them in a U shape and bent one end so i could grab onto them, put one paper clip threw the top of the mesh and one at the bottom, then I yanked the top, then the bottom and repeated til it came out.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  6. #6 Re: how do you remove the throttle body mesh?
    ^Right.
    Keep it there.
    It's not a restriction.
  7. #7 Re: how do you remove the throttle body mesh?
    St Thomas Ontario
    Quote Originally Posted by JLiss View Post
    to clean the TB maybe. and you can get a incar tune to fix having the mesh out as long you have 6 inches or more of straight tubing after the maf.
  8. #8 Re: how do you remove the throttle body mesh?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I pulled mine out to clean it. I honestly would never take it out incase for some reason a hole would develope in the air box or cone falls off. At least it might help stop bigger debries.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  9. #9 Re: how do you remove the throttle body mesh?
    Quote Originally Posted by Grimsin View Post
    to clean the TB maybe. and you can get a incar tune to fix having the mesh out as long you have 6 inches or more or straight tubing after the maf.
    6" of tubing AFTER the MAF?
    Are you using an external MAF then in your L36 car?
  10. #10 Re: how do you remove the throttle body mesh?
    St Thomas Ontario
    6" of tubing after the maf correct.
    I had mine out since the incar retune from overkill, i told him the screen wasn't in there, he said it was fine and he did 1.5-2 hours of tuning and said the readings weren't fluctuating and the car was easy to tune.
    got my 800 km on a full tank of gas without it, did it make a difference in power? I don't think so but hasn't caused me any problems.
  11. #11 Re: how do you remove the throttle body mesh?
    Dec 2012
    Aurora, IL
    no, that serve's for ACCURATE readings period, there is no flow restriction, dont you know people including myself, have added that to their boosted application to flow better and smoother, more accurate when tuning. that contributes to helping the maf keep things stable and consistent, epsecially in the boosted application where maf in boost is vital.
    here is some hard data we have done on testing it
    before smoke going through maf housing
    [img]http://i135.photobucket.com/albums/q...01/natflow.jpg[/img]
    after with honey comb n
    [img]http://i135.photobucket.com/albums/q...anno01/air.jpg[/img]
    before screen log
    [img]http://i101.photobucket.com/albums/m...en100mmMaf.jpg[/img]
    [img]http://i135.photobucket.com/albums/q...anno01/sam.jpg[/img]
  12. #12 Re: how do you remove the throttle body mesh?
    St Thomas Ontario
    that doesnt look exactly like engine circumstances(that box it huge for the tiny amount of air coming in. im not gonna argue though all i did was look at overkills reading and they were smooth the intake setup i made was smooth enough. and my qtr mile times of 15.7-15.6 all night also shows it wasnt making a huge power loss/gain due to tumbled air.
  13. #13 Re: how do you remove the throttle body mesh?
    Dec 2012
    Aurora, IL
    lol well the bigger box was used to so that you can visually see the difference, bigger or smaller the outcome is the same. But i mean lots of cars run them out the factory without them, some aftermarket companies weld them into their intakes as well. i personally like them there, as air is stupid and will go all over the place, the honeycomb directs air flow consistently the same without change.
  14. #14 Re: how do you remove the throttle body mesh?
    I like mine there for the peace and mind of not being able to such something into the engine that could damage it.
  15. #15 Re: how do you remove the throttle body mesh?
    Jan 2013
    Sioux Falls, SD
    The reason i want to take it off is to clean throttle body and maf. Im not mechanically inclined to be able to take the whole thing off and i figured some cleaning is better than none
  16. #16 Re: how do you remove the throttle body mesh?
    St Thomas Ontario
    ya it does direct air flow perfectly no mater what. only reason i honestly did it was cause i destroyed it the day before the tune by stepping on it accidently lmao, glad it works without it, also happy you can discuss it without a huge flame war overtaking this poor OPS thread lol.
    To the op: YA THE tb's need to been cleaned they get pretty gunked up, more on the other side of the tb though(not the side your trying to get to).
  17. #17 Re: how do you remove the throttle body mesh?
    Jan 2013
    Sioux Falls, SD
    I've read how to remove the tb from this forum but im afraid ill mess us something since im in college and its my dd lol
  18. #18 Re: how do you remove the throttle body mesh?
    the maf un screws from the top of the TB, no need to take the TB off to clean it. if you clean the TB you want to take the maf off as you dont want anything to touch the maf but maf cleaner.
  19. #19 Re: how do you remove the throttle body mesh?
    Jan 2013
    Sioux Falls, SD
    Alright thanks for the help i might give it another go when it gets warmer out
  20. #20 Re: how do you remove the throttle body mesh?
    Apr 2012
    Goderich, Ontario
    ...got my 800 km on a full tank of gas ...
    wtf! the most I've seen in bolth of my Grand Prix's is 550-600km to a tank.
  1. How to remove stuck gasket from throttle body?
    By RideWithPride in forum General Tech Discussion
    Last Post: 07-30-2012, 05:27 PM
  2. How do I remove the throttle cable?
    By Boostdreamer in forum General Tech Discussion
    Last Post: 10-09-2011, 05:48 PM
  3. Can I remove the throttle body screen??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 09:00 AM
