Thread: cone air intake
Results 1 to 7 of 7
  1. #1 cone air intake
    SE Level Member MikeD's Avatar
    Jan 2013
    Iowa
    Ive been looking around on here and a lot of people use the cone intakes and I want to put one in I just have a question before I do something I shouldn't
    can I just unbolt the stock air box then bolt a cone onto the mass airflow sensor?
    I have a 2000 grand prix se
  2. #2 Re: cone air intake
    GTP Level Member buickman104's Avatar
    NYC
    Yes, you can but then you would suck in lots of hot air from the engine bay. Once your IAT sensor see all that hot air it will pull timing and you will lose power.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by buickman104 View Post
    Is that right?
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  4. #4 Re: cone air intake
    I can see this if it was the middle of july and 90-100º outside. While the car is moving temps are within 20º of ambient for me, then once you goose it, its even closer to ambient with how much air you are sucking in. Tons of us run hot air intakes with zero problems and no heat shields. You will be fine running it that way.
  5. #5 Re: cone air intake
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    I don't even have a iat anymore
  6. #6 Re: cone air intake
    Willoughby, Ohio
    who cares if it "hot" theres way less zero restriction with a filter on the end of the TB/maf vs a bunch of tubing jammed in a fender...yay for mpg bump or two
  7. #7 Re: cone air intake
    Yoga city
    just do it!
  1. Open cone intake clarification
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 08:25 AM
  2. Open Cone Intake
    By demetriuslopez in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 11:11 AM
  3. Open cone intake
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-11-2010, 05:01 PM
