I have removed the motor lift brace and the cosmetic cover brace to access the valve cover gaskets I am changing. The cosmetic cover bracket does not seem to be an issue, however I am unable to put the motor lift point brace back on. Any help, particularly with a photo or a link showing this lift point would be greatly appreciated, as I am getting whipped trying to locate the correct manifold stud to use for it's nut, and finding the threaded hole that the bolt inserts into. Car is a 2001 gp gt 3800 vin K. Thanks kindly and politely - Lyndal
