Thread: My 2008 GrandPrix GXP
Results 1 to 2 of 2
  1. #1 My 2008 GrandPrix GXP
    Jan 2013
    Alabama
    Ive been having issues after my oil and air filer were changed last month..Found my oil filter was out a little but my car is still saying reduced engine power..It surges then bogs down..I had someone run a code on it and it said Throttle position censor a and b..Can someone help??? I would like to fix this on my own and prove to my hubs I can.
  2. #2 Re: My 2008 GrandPrix GXP
    From the little info you gave me, it sounds like either the pedal postion sensor or the throttle body itself is bad. Your GXP being a drive by wire car instead of by a cable uses 2 sensor to figure out how far you are pushing down the pedal thus telling the Throttle body to open a certain amount.
    Without the code number its had to say if its the PPS or the throttle body.
  1. GrandPrix GXP
    By dammad9597 in forum Introductions/Noob Questions
    Last Post: 07-09-2011, 09:21 AM
  2. Engine whine!! 2008 grandprix gxp 5.3 v8
    By tonio301 in forum 5.3L V8 (LS4)
    Last Post: 06-07-2011, 10:43 AM
  3. 2008 Grandprix 56K Miles-- Wheel Bearings replacement.
    By magickid in forum Tires & Wheels
    Last Post: 04-09-2011, 07:25 PM
  4. 1988 grandprix tranny to 1993 grandprix
    By avaitors in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 09-14-2009, 03:34 AM
