Thread: 04 GTP with comp G package service alarm
Results 1 to 3 of 3
  1. #1 04 GTP with comp G package service alarm
    Jan 2013
    casa grande az
    Hi guys; new guy question?
    I've had my GTP since new, no mods to speak of, and about a week ago I saw, out of nowhere the service alams.
    Traction control off
    service stability control
    service brake system
    service ABS system
    service traction control system
    it came on once,I shut down the car did a restart and it went away. over the last week it comes on at start and stays on, repeating the alarms, I also have the idiot lights for these systems lit up. I live in Arizona, the car has about 70 K on the clock and being an in town car it has'nt needed a brake job. the only warranty work was on the transmission and HUD at around 30 thousand miles. I've read a few things about the ECU, as well as the wheel sensor harness connections. GM had a recall on some part of the braking but I'm not sure if it's applicable, Any help would be great.
    THANKS!!!!
  2. #2 Re: 04 GTP with comp G package service alarm
    Sounds like you need to get the car scanned to see why the car is throwing those lights.
    It could be as simple as a bad wheel bearing to a wire fault or at the worst the ABS modlue took a dump on you. Those can be sent off for repair to module masters for a price and like a 5 year warranty.
    But I would first get the car scanned with a scanner that can read ABS codes and go from there.
  3. #3 Re: 04 GTP with comp G package service alarm
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    could be a failing a speed sensor...too bad that means the hub assembly...pull abs codes
    COMP G
  1. Alarm going off inside car when reaching highway speeds..coolant temp alarm?
    By MattTheBaker123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2012, 09:39 AM
  2. Found a 2004 Grand Prix GTP w/ Comp package...thoughts?
    By dancadman in forum General Grand Prix Discussion
    Last Post: 06-29-2012, 02:14 PM
  3. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  4. comp g package
    By des19 in forum General Tech Discussion
    Last Post: 07-11-2011, 06:31 PM
