Thread: Need help fixing this problem
Results 1 to 14 of 14
  1. #1 Need help fixing this problem
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    So on gp when u turn the heat on my head lights turn off and so does my d.I.c but my headlights turn back on and d.I.c takes a good 10 minutes to turn on but it only lights up and says my doors are open and my trunk are open and also my windshield wiper fluid is out and I also have to reset my mpg cause it just bounces around
    And I know that I got a hole in my catalytic converter and I'm not getting the best mpg
    And I've looked for messed up wires when I had the dash apart and I don't want something serious happen
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: Need help fixing this problem
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    gremlins
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Need help fixing this problem
    Nov 2012
    Madison
    how old is your battery?
    when mine died it put on quite the possessed light show.
  4. #4 Re: Need help fixing this problem
    Dec 2012
    grand rapids
    Quote Originally Posted by Erik Adam Rodriguez View Post
    gremlins
    Gremlins??
  5. #5 Re: Need help fixing this problem
    Dec 2012
    grand rapids
    Quote Originally Posted by spazzz View Post
    my battery is brand new
  6. #6 Re: Need help fixing this problem
    I live here. DirtDog's Avatar
    Jun 2012
    gremlins
  7. #7 Re: Need help fixing this problem
    Sep 2012
    bridgeport,NY
    it sounds like your car is losing alot of voltage. test the output of the alt, it could be going bad
  8. #8 Re: Need help fixing this problem
    Dec 2012
    grand rapids
    Alright I'll check it out in the next day or so
    I thought about buying and new heater switch from junk yard the could draining power cause it broke just sucking alot of power to it cause it only works on the highest level
  9. #9 Re: Need help fixing this problem
    Sep 2012
    bridgeport,NY
    only working on hishest level is the resistor, it wouldnt cause the power loss issue. when i bought my 97 the battery was cracked. to get it home i jumped it and made sure not to touch the radio or anything but i went to lreach for my cigs and hit the heater and the car died.
  10. #10 Re: Need help fixing this problem
    Yoga city
    uhm long shot, but i had my hvac panel go on me and caused random issues with using headlights and fans coming on. pull the Hvac panel unplug the electrical there and see if it continues. could just be a short somewhere
  11. #11 Re: Need help fixing this problem
    Dec 2012
    grand rapids
    The heater and ac switches
  12. #12 Re: Need help fixing this problem
    Dec 2012
    grand rapids
    Well it wasn't the hvac got a new one
    When I turn the heat on headlights shut off
    You can hear the head lights turn off when you turn the heater switch on
    So idk what to do next
  13. #13 Re: Need help fixing this problem
    Dec 2012
    grand rapids
    I talked to a guy he said it could be the blower resistor
  14. #14 Re: Need help fixing this problem
    Nov 2012
    Madison
    Grand Prixs Of North America • View topic - Heater fan headlight issues
    might want to give this a read,it looks pretty close to your problem.
    Thanks to our friends at GPONA
  1. Fixing your intermittent stalling problem!
    By Pittman06 in forum How To Write-Ups/Tech Tips
    Last Post: 05-14-2013, 09:35 PM
  2. Fixing 4th
    By Cummins97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2012, 07:13 AM
  3. i need help fixing this problem i have thanks
    By sca555 in forum General Tech Discussion
    Last Post: 09-06-2010, 01:26 PM
  4. **FIXED!** Fixing One Problem Created Another...
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-09-2010, 08:31 PM
  5. fixing hud???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 12-23-2008, 10:45 AM
