Thread: Mods for 3.6 Pulley?
Results 1 to 9 of 9
  1. #1 Mods for 3.6 Pulley?
    Dec 2012
    Billings
    Hello, i am new to this forum, i have a 2002 GTP and am kind of tight on money because i bought this car all stock except i believe its a 3.4 pulley that was on it, and it obviosly broke a rod or something because of no supporting mods at all, im hoping i just spun a bearing, so i am currently in the process of rebuilding it and i know i cant just leave that pulley on there with no mods when i get it going again, i am kind of on a small budget so what my question comes down to is if i get the modular pulley system and get the 3.6 pulley...will i be safe running a 3.6 with a 3'' downpipe, intense pcm, autolie 104, 180* thermostat, and a fender well intake?...i just dont have money for headers and really dont want to buy the $200+ scan tool right now anyway to keep the 3.4...so with those simple mods be good enough for a 3.6 to be safe?
    thanks for any help!
  2. #2 Re: Mods for 3.6 Pulley?
    Should be ok but headers are only $200 how are you going about rebuilding? You likely have a chipped piston
  3. #3 Re: Mods for 3.6 Pulley?
    Texas
    Yes those supporting mods should be fine ONLY if your engine is good working order. And agree that you probably chipped a Piston, pull the heads and post the carnage.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: Mods for 3.6 Pulley?
    Dec 2012
    Billings
    My aunt is a mechanic and is helping me go about rebuilding it, we just got the engine out, and now i just have to start tearing everything apart..hoping that i dont need a whole new block...i just found out about the front powerlog and rear ported manifold from zzp, i might do that and still keep the 3.6 to be safe untill i can afford a scan guage to check my kr...does anybody know if a simple shop scan tool or anything can scan for kr?
  5. #5 Re: Mods for 3.6 Pulley?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    You can buy a set of headers of ebay.
    Lots of people roll with these, they work good, you should snag them up:
    Racing Manifold Header Exhaust Grand Prix GTP Buick Regal Impala Monte Carlo 3 8 | eBay
    And for scanning KR, if you have an Android phone you can buy an App call "Torque" its like $5 and youll also need the Torque OBDII attachement, likes $25 on ebay. Once you buy it, change some settings (google how to cause i dont remember) then uninstall it, then re-install it. Then you can successfully check for KR rather than spending the money on an Aeroforce.
  6. #6 Re: Mods for 3.6 Pulley?
    I live here. TLSheff's Avatar
    Hrmmm....
    So we have 3 responses to a New Member with a post count of 2, who is asking about modding.... any nobody thought to mention the Safely Modding Thread?
    again... up to me.
    http://www.grandprixforums.net/safel...0-a-67580.html
    http://www.grandprixforums.net/ultim...0-a-49055.html
    Also since you're new and all... check over these and make sure the car is good to go before you throw money at mods and break something else.
    http://www.grandprixforums.net/97-03...ems-60802.html
    Good luck, and WELCOME!!!
  7. #7 Re: Mods for 3.6 Pulley?
    If you do the SD headers pcm plugs you could almost run a 3.4 pulley but should definitely be able to run a 3.5.
  8. #8 Re: Mods for 3.6 Pulley?
    Dec 2012
    Billings
    ok thanks to everyone!..and for the android phone deal..does that only work for androids? if so, will the Droid X phone work?
  9. #9 Re: Mods for 3.6 Pulley?
    Yeah it'll work with a droid x
  1. zzp 3.6 pulley supporting mods
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 12-21-2011, 09:06 PM
  2. smallest pulley with the following mods?
    By mezzoni in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2011, 09:47 PM
  3. What MODS Do I NEED For A 3.5 Pulley?????
    By szalajka05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2011, 08:24 AM
  4. could i run a 3.4 pulley with these mods?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 03:17 PM
  5. 3.5 Pulley WITH supporting mods
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 11:41 AM
