I have these HID, but one of the headlights stays on for about a minute then turns off. I would then turn them off and back on, and they would then turn on for about 10 seconds. I have no idea what is going on. Thanks
What brand do you have?
check grounds and ballast connections
Not sure of the brand I'll have to check in the morning. I'm pretty sure its the ballast. Would I need to do a relay harness?
had a similar problem with my HID's. there is not enough juice to power them through the OE harness. Get the relay harness and it should solve your problems. Installation instructions you can find on youtube.
Even for normal bulbs I always build a relay harness for my lights. On my Jimy through the factory wiring I had 11.7 volts at the headlight. after building a relay harness I had the alternators full 14.3 volts at the bulb. made the silverstar Ultras I had in it REALLY bright and white. For HID I would definitely reccomend the harness too. gotta get the proper voltage to your lights.
