Thread: Hi all! I have a 2000 Grand Prix GT.Fuel pump, worked. Now crank no start. no prime
Results 1 to 4 of 4
  1. #1 Hi all! I have a 2000 Grand Prix GT.Fuel pump, worked. Now crank no start. no prime
    Nov 2012
    IA
    I have mechanically training. Checked relay and fuse and both good. I have put 2 fuel pumps in. And the one in there was only in for almost a year. Then it started intermittently, could wait half hour and would start. So replaced pump again under warranty 2 or 3 weeks ago. Now it wont start, again. Checked relay, put new in. Checked fuse, fine. So I have most of my tools from working in shops. I checked for fuel in regulator nothing. So I am thinking the harness update is not wired good or a kink. When it did run after first fuel pump smelled like fuel in car. Thanks Aimo
  2. #2 Re: Hi all! I have a 2000 Grand Prix GT.Fuel pump, worked. Now crank no start. no pri
    It just cranks and cranks but doesn't start? Have you ever changed the fuel filter?
  3. #3 Re: Hi all! I have a 2000 Grand Prix GT.Fuel pump, worked. Now crank no start. no pri
    If it cranks as you say and you have no fuel...have you checked for power at the fuel pump? You may have a wiring issue or be getting a bunch of bad pumps.
  4. #4 Re: Hi all! I have a 2000 Grand Prix GT.Fuel pump, worked. Now crank no start. no pri
    GTP Level Member 1ATony's Avatar
    mass
    welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  1. grand prix wont start, fuel pump is good.
    By 1986c10 in forum General Tech Discussion
    Last Post: 12-19-2011, 08:51 PM
  2. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
  3. Knock because of crank pulley or fuel pump
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2009, 10:27 AM
