Thread: Power steering help!
Results 1 to 6 of 6
  1. #1 Power steering help!
    Nov 2012
    Niagara Falls, NY
    How hard is it to change the power steering pressure and return hoses on a 2004 Grand Prix GT2? Does anyone have step-by-step instructions too?
  2. #2 Re: Power steering help!
    It's not to hard just a little hard to get at.
  3. #3 Re: Power steering help!
    Nov 2012
    Niagara Falls, NY
    Hi dsmuts - happy thanksgiving and thank you for your reply - do you think it can be done using jack stands or will I need a lift?
  4. #4 Re: Power steering help!
    jack stands would do, you need a 18 mm line wrench to get the lines off the rack, and theres another line nut to the pump, you need to take the pass front wheel off to get to them from the wheel well.
    the line just clip to the sub frame and loop around. not a bug deal to change.
    the lines on the rack are located on the driver side of the car, you can get them from underneath the car.
  5. #5 Re: Power steering help!
    Jacks will work fine. Make sure you use a line wrench because a regular 18mm wrench will round the nut off.
  6. #6 Re: Power steering help!
    Nov 2012
    Niagara Falls, NY
    Hi scottydoggs, dsmuts,
    Thank you both - just what i wanted to hear!! Take care!
  1. power steering help
    By redefine91 in forum Brakes/Suspension/Chassis
    Last Post: 12-22-2011, 03:15 PM
  2. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  3. No Power Steering?
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2011, 12:24 PM
  4. ABS, TC, and Power Steering off...:(
    By nikhackgt2 in forum Brakes/Suspension/Chassis
    Last Post: 02-19-2009, 12:09 PM
  5. Power Steering
    By greengaels2 in forum General Tech Discussion
    Last Post: 12-29-2008, 01:45 PM
