Thread: New to site. Need to repair rear strut mount area inside trunk.
Results 1 to 3 of 3
  1. #1 New to site. Need to repair rear strut mount area inside trunk.
    Nov 2012
    Poynette, WI
    We have two black 97 four door GTP's. One of them is nearly undrivable due to rear strut mount rust at the top of the body where the 3 bolts go thru. While searching for a donor car from which I can cut out the upper portion and then weld/bolt in, I was told patch kits can be purchased from some suppliers. If anyone knows this to be true, please point me in that direction. Neither car deserves to die yet. Thanks.
  2. #2 Re: New to site. Need to repair rear strut mount area inside trunk.
    Mar 2012
    NC
    I haven't seen any repair kits. I made my own. If you search "IncREDi-hoopdy" you'll find my 5 speed build and rear strut tower rust my dad repaired.
  3. #3 Re: New to site. Need to repair rear strut mount area inside trunk.
    Nov 2012
    Poynette, WI
    Thanks. I watched a guy do one on you tube. He just cut a piece of metal to fit, then welded it in. Not sure how easily whole top six inches or so will come out of a donor but I believe that will be a better and stronger method. Ride height could possibly change by the thickness of the metal but it beats what we have now.
    Just went thru all the pages of your trans swap. Incredible amount of work you did. Wish I had your youth - and your Dad. As one of the posts mentioned, he has some serious skills. I didn't see it but was wondering if Redline ever got back with those Chrysler part #'s. Oh well, I'm sure I can find them. Thanks again.
  1. Strut Mount
    By rvnwlf in forum Brakes/Suspension/Chassis
    Last Post: 06-02-2012, 07:54 AM
  2. How to repair the trunk release button?
    By MzDyme in forum Introductions/Noob Questions
    Last Post: 07-28-2011, 06:22 AM
  3. Rear upper strut mount
    By Ryan D. in forum Brakes/Suspension/Chassis
    Last Post: 06-21-2011, 10:35 PM
  4. Need help with with rear strut mount??
    By 99GTP99 in forum General Tech Discussion
    Last Post: 02-18-2010, 08:27 AM
  5. missing spacer on rear strut mount '06 GXP
    By tta1401 in forum General Tech Discussion
    Last Post: 07-25-2009, 05:19 PM
