Thread: Can i just strait pipe?
Results 1 to 20 of 23
  1. #1 Can i just strait pipe?
    Sep 2012
    Indiana
    I have a 04 Grand prix GT. It runs rough sometimes and the code checker says its fuel filter and cat. So. instead of spending a lot of money on a new cat/cats. Can i just strait pipe over it? Would that fix it? or just cause more problems?
    Thanks guys!
  2. #2 Re: Can i just strait pipe?
    Straight. It'll throw codes if no cat.
  3. #3 Re: Can i just strait pipe?
    The Boss Iceman6669's Avatar
    Jun 2011
    Can you straight pipe it.. Yes. Should you.. NO... With no res it will sound like butt. If you wanna get rid of the cat you need to get the rear O2 sim.
    2011 F-150 Yote powered
  4. #4 Re: Can i just strait pipe?
    I've never seen a car throw a code for a fuel filter. If you give us the code numbers we could help you out a lot more.
  5. #5 Re: Can i just strait pipe?
    Sep 2012
    Indiana
    Well a buddy of mine is a mechanic. He has a high tech computer code checker.. He said thats what it said. Would it really sound that bad? Is there any other way of Not spending a boat load of money on cats?
  6. #6 Re: Can i just strait pipe?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by phantomplanet89 View Post
    GPONA #1 Cyber Bully
  7. #7 Re: Can i just strait pipe?
    Car will run worse with no cat converter.
    04+ cant use a o2 sim.
    Buy a new cat.
  8. #8 Re: Can i just strait pipe?
    Sep 2012
    Indiana
    Dang. Thats what i was afraid of. Money is a little tight right now. Was just checking if was a cheaper way to get around that. Thanks guys
  9. #9 Re: Can i just strait pipe?
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    can you run with no cat, yes. should you? if you can still pass emissions without it then why not but you will have to take great care of your engine in order to do this.
    fivefingerdeathpunch...would no cat actually cause it to run worse? that doesnt make sense to me since guys buy catless downpipes to get more power.
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  10. #10 Re: Can i just strait pipe?
    lol @ catless...thinking it gives more power.
  11. #11 Re: Can i just strait pipe?
    Jun 2012
    Connecticut
    well a cat obstructs airflow somewhat. if you have enough other mods its bounds to make somewhat of a difference.
    2005 Grand Prix GT
  12. #12 Re: Can i just strait pipe?
    The WBody cat...betting it isn't clogged like they always do...
    Aren't a restriction at all...you'll gain 1~ WHP...if that...deleting it. The main reason most people delete the cat is for sound and the peace of mind it'll never clog.
    That's it.
  13. #13 Re: Can i just strait pipe?
    Jun 2012
    Connecticut
    alright, and you did just say that you do gain minimal hp from it so i wasnt completely wrong either lol
    2005 Grand Prix GT
  14. #14 Re: Can i just strait pipe?
    The temperature change outside has more gains for your car than deleting the cat.
    So no, the only thing you'll be getting is noise.
  15. #15 Re: Can i just strait pipe?
    Yes his car would run worse and get terrible gas mileage.
    All 01+ cars use the rear o2 for diag and fueling of sorts in the PCM, if it has so cat all the readings will be wrong and thus dump fuel.
  16. #16 Re: Can i just strait pipe?
    Jun 2012
    Connecticut
    gotcha, see i didnt know that guys lol im still learning like i said in the chat lol
    2005 Grand Prix GT
  17. #17 Re: Can i just strait pipe?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    So then if you get a hi-flow cat would that then effect your gas mileage? or no because you still have a cat on there?
  18. #18 Re: Can i just strait pipe?
    Jun 2011
    Isnt that what the rear O2 sim does, it simulates a working cat so the car diagnostics works... 97-00 dont need the sim just have an SES light till it gets tuned out. 01+ have Cat Diagnostics and NEED the O2 sim to go catless or else yes the computer dumps fuel.
  19. #19 Re: Can i just strait pipe?
    Quote Originally Posted by hockeybawler View Post
    Most if not all highflow cats will still set the SES off because it flows too well.
    Quote Originally Posted by Iceman6669 View Post
    They say that 01-03 can use the sim, but it doesnt always work, and 04+ cant use a sim, because it wont work at all.
    OP's car is 04.
  20. #20 Re: Can i just strait pipe?
    Jun 2011
    OP's car is 04.
    I didn't know that it only works on 01-03 cars... I assumed all cars that have the Cat Diagnostics it would work on.
  1. New Cat And Pipe
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-20-2011, 09:00 AM
  2. Down pipe
    By Royalblue in forum General Tech Discussion
    Last Post: 06-13-2011, 04:28 PM
  3. zzp down pipe
    By 2005gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2011, 01:46 PM
  4. I just put a down pipe on my o4 gtp need help ?
    By 98gtp1000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 12:39 AM
  5. Down pipe
    By JB Miller in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 12:40 AM
