Thread: tranny swap
Results 1 to 14 of 14
  1. #1 tranny swap
    Sep 2012
    sylamr
    hello guys. im new to the forum. i wanted to join a gp forum because i have a bone stock gp gt other then my performance chip. i wanna put 5 or 6 speed transmission in my gt but i'd like it to be an auto(sissy i know) i want auto because i have a problem with breaking my right hand so it gets hard to shift,lol. just wondering if its possible and how much it would cost. and what i would have to do. thanks guys
  2. #2 Re: tranny swap
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Welcome. Please tell us more about this "performance chip". Six-speed swaps have been done before, both auto and manual, but it wouldn't be worth it until you got some powah!
    GPONA #1 Cyber Bully
  3. #3 Re: tranny swap
    Omaha, NE
    What benefit are you trying to achieve by going to a 5 or 6 speed automatic?
    And I would love to hear more about this performance chip as well
  4. #4 Re: tranny swap
    Sep 2012
    sylamr
    or swapping for a gtp motor and modding from there. im not quite sure what i wanna do. so i'd also like opinions from real gp fans. im just coming into my own on the car and have seen fantastic things from them
  5. #5 Re: tranny swap
    Sep 2012
    sylamr
    The GF performance chip reprograms your air/fuel ratio,ignition timing and other aspects to safely increase the power, while increaing fuel economy the chip is designed to make your car run smoother and cooler at the same time. check out website.gfchips.com and as for the tranny i want a 5 or 6 speed because i was looking into dropping a v8 into it. like i said i am a noob to the whole modding a car so whatever you guys could help out with without looking down on me too much would be great
  6. #6 Re: tranny swap
    Omaha, NE
    First off, remove the chip before you cause any damage to the car.
    Then read this thread about how to SAFELY mod your 3800: http://www.grandprixforums.net/safel...0-a-67580.html
    What V8 engine were you planning on going with? That would help determine the proper trans for the setup you had in mind.
  7. #7 Re: tranny swap
    Sep 2012
    sylamr
    yes?
  8. #8 Re: tranny swap
    Yoga city
    is this guy for realz? lmao
  9. #9 Re: tranny swap
    Sep 2012
    sylamr
    chip can be pulled off right now...and i was very curious to see if an ls2 would fit. but even then the gto auto came with a 4 speed.
  10. #10 Re: tranny swap
    You realize fwd and rwd are 2 very different things right?
  11. #11 Re: tranny swap
    Omaha, NE
    Most GM automatic gearboxes are going to be 4 speeds. You only need 3 gears to get down a 1/4 mile.
    As a matter of fact, off hand, I can't think of a GM with an automatic gearbox that has a 5 speed. Most cars with 6 speeds are cruisers anyway.
    As far as dropping in an LSx, there will be A LOT of custom fabrication involved. I think the last person to RWD swap a GP spent 20k. There really isn't a reason it can't be done, but the time and cost involved would be more than the car is worth, especailly when you can get a good turbo setup and run 10s and 11s all day long for a fraction of the cost.
  12. #12 Re: tranny swap
    Yoga city
    just get a whole ls4 cradel and bolt it up you pansie, motors can be had for 2500$ dont go into craziness. i think you need to stop thinking your shadetree mechanic lol
  13. #13 Re: tranny swap
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    So lets sum this up.
    "Performance Chip", dangerous garbage.
    V8 swap, not worth it.
    Six-speed swap, you do not have enough invested in your car yet.
  14. #14 Re: tranny swap
    Omaha, NE
    Chips are junk, a pcm from a vendor or tuning software are the way to go.
    V8 swap, probably not worth it. If you wanted to go V8 I suppose a GXP swap wouldn't be the worst thing to do, but that's an LS4, and front wheel drive.
    You can do a getrag manual swap. Do a search for Kuntzie, his install went smooth.
  1. Oil Pan/Tranny Pan Swap?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2011, 08:24 PM
  2. 2.8 l tranny swap tp a 3.1
    By avaitors in forum General Tech Discussion
    Last Post: 09-15-2009, 01:33 PM
  3. tranny swap
    By gonzo915gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2009, 03:10 PM
  4. tranny swap
    By kbradley in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2009, 04:59 PM
  5. Tranny swap
    Last Post: 04-23-2009, 07:45 AM
