Thread: Noobb Brake/Suspension ???s 2000 GP
Results 1 to 4 of 4
  1. #1 Noobb Brake/Suspension ???s 2000 GP
    Sep 2012
    Indiana
    Hello All,
    Long time follower, first time registerer/poster. I have questions about an issue that occurred. Last week, the wife was on a drive back from visiting family, a few hours drive both ways, and the RF caliper bolts on her 2000 GP came loose while she was driving and it caused the wheel to lock in forward position because it wrenched the caliper into the rim. I had changed the brakes and rotors on both sides about two months ago and had everything back together just fine (or so I thought).
    My questions would be, 1) Is it possible for them to even vibrate loose like that, in that situation? 2) Could over-tightening/under-tightening cause the bolts to back themselves out easier? I would think that, if I had even forgotten to tighten them, they would have came loose a long time ago. Here's the other catch, her sway bar is broken off from the drivers side at the bolt/bushing, so her suspension and front end is taking way more vibration and jolts then I would think that it normally does.
    Your thoughts on this would be appreciated. Thanks!
  2. #2 Re: Noobb Brake/Suspension ???s 2000 GP
    Just sounds like the bolts didnt get tight all the way.
  3. #3 Re: Noobb Brake/Suspension ???s 2000 GP
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Agree with FFDP
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  4. #4 Re: Noobb Brake/Suspension ???s 2000 GP
    sounds like you forgot to tighten them up real good.
    the sway bar being broken will cause some pot holes to sound and feel worse then they are. they go for a bout 120 or less for a dorman solid sway bar. ( comes with all new end links, sway bar bushings caps and bolts)
    the stock one is hollow and the ends rust and break off at the end links.
  1. Suspension and brake problems, dont know where to start
    By GTLGDP in forum General Tech Discussion
    Last Post: 04-21-2012, 02:27 PM
  2. A new place for W-body suspension and brake upgrades!?!? Coilovers??!!
    By copgtp in forum General Grand Prix Discussion
    Last Post: 03-23-2012, 08:58 AM
  3. brake & suspension ideas?
    By superv6 in forum Brakes/Suspension/Chassis
    Last Post: 07-25-2009, 02:05 AM
  4. I need your input on my 2000 GTP Suspension
    By cprher in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 02:58 PM
  5. Comp G suspension in a 2000 GP?
    By RNUOVR in forum Brakes/Suspension/Chassis
    Last Post: 01-26-2008, 12:48 AM
